Weird loping - Mustang Evolution
Old 04-08-2012, 07:36 PM   #1
jwhayne0001's Avatar
Weird loping
Here recently after I drive my car and park it to go into a store or something, come back out, start it, it begins loping and running like crap, is this from the heat soak on my cold air intake? It clears up after I drive away
jwhayne0001 is offline   Reply With Quote
Old 04-08-2012, 09:15 PM   #2
hmmm....i think your gonna need to check fuel pressure when this happens. but i would do the basics to.clean maf iac and check tps.make sure you have no vacuum lines.and the coil and fuel filter may need checked.
i dont know for sure but i doubt your cai is causing this.
Old 04-09-2012, 12:01 AM   #3
Re: Weird loping
I would suspect the PIP or TFI module maybe.
Old 04-09-2012, 05:47 AM   #4
Call me stupid but what are each of those
---------- Post added at 06:46 AM ---------- Previous post was at 06:23 AM ----------
Answered my own questions via google, are each available at auto parts stores? And would it be simpler/easier to just buy a whole new distributor? And the TFI I have read is on the passenger side, what does it look like?
---------- Post added at 06:47 AM ---------- Previous post was at 06:46 AM ----------
Also American muscle has the msd blaster coil with TFI will these take place of that sensor?
Old 04-09-2012, 05:54 AM   #5
http://351winsor.com/joel/Ignition_Systems/tfi2.html
Both parts are testable.this is the test for the module found in the stickys. There is a test for the pip but I'm not sure if that's in sticky or not.but im sure Haynes or google could find that.
I would test both parts imo before spending $$
---------- Post added at 06:54 AM ---------- Previous post was at 06:51 AM ----------
No it won't.its just the coil.there is a chance it could be suspect to but I would look at the other parts first
Old 04-09-2012, 02:43 PM   #6
Re: Weird loping
Something else I just thought of, you might check your IAT (Intake Air Temperature) and ECT (Engine Coolant Temperature) sensors too. Either one could be failing and signalling that you need more fuel.
Old 04-09-2012, 05:22 PM   #7
I have noticed it running rich by smell
Old 04-09-2012, 05:26 PM   #8
Re: Weird loping
Then we may be on to something with those temp sensors.
If they act up they could be signalling for more fuel when it is not needed.
Old 04-10-2012, 05:37 AM   #9
IATS is screwed into my cold air pipe correct?
Old 04-10-2012, 06:17 AM   #10
Yeah it should be on your coldair intake. U should be able to find it. The wiring ties into the maf harness!
Robbie94gt is offline   Reply With Quote
Old 04-10-2012, 06:59 AM   #11
Yeah I found it wonder of the oil from my filter has got on it
Old 04-10-2012, 07:22 AM   #12
My car was doing the same thng a while back. Sounded like it had a cam in it. But it could be fro the oil not letting it get a accurate reading. I would clean the maf and iat to c if that helps
---------- Post added at 10:22 AM ---------- Previous post was at 10:20 AM ----------
Old 04-10-2012, 01:08 PM   #13
What was your remedy for yours?
Old 04-10-2012, 01:46 PM   #14
To be completly honest I'm not sure. I've done alot of little things tune up wise. But mine didn't lope like that all the time. It was just kind of random. Hope u get it figured out tho
Old 04-10-2012, 02:05 PM   #15
Mine does it when it sits hot, like Saturday went to a car show, went to leave 30 mins later and then it went to hell till I gave it a little gas
Old 04-10-2012, 02:55 PM   #16
Re: Weird loping
If it has then your MAF sensor needs to be cleaned too.
Use alcohol or approved carb cleaner and a Q-tip.
Be very careful not to break the wire on the MAF sensor.
Old 04-10-2012, 08:50 PM   #17
MAF sensor cleaner safe for both?
Old 04-11-2012, 07:54 AM   #18
Titus Wadicus
svtlx's Avatar
Re: Weird loping
sooo when is the last time you put plugs in it? sometimes when the plugs are on their way out they will break-up when you start it... or babsicly when the plugs are cold frm sitting. once u been driving for a few minutes the plugs warm up and will conduct spark better.
i would check those first... thats just my opinion
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 04-11-2012, 08:08 AM   #19
When I start it after a cold soak (over night) it runs like a top
Old 04-11-2012, 08:15 AM   #20
Titus Wadicus
svtlx's Avatar
Re: Weird loping
hmmmm, maybe wut the other guys said then...
Old 04-11-2012, 08:39 AM   #21
I would still pull all the plugs and check them like svtlx said. Now that I'm thinking about it. I think thst might have been what was causing mine to do thst a while back. On one of my plugs the white insulator had a crack all the way down it. I replaced thst and it solved my wierd lope and also I had a high rpm miss. Does it ever cut out or miss on u at high rpms?
Old 04-11-2012, 10:48 AM   #22
No miss at high rpms guess I'll pull a few plugs out and see what they look like, no idea how long ago they we replaced they are motorcrafts atleast
Old 04-11-2012, 11:53 AM   #23
I would pull all of them just to be sure.just incase only one is bad.
Old 04-12-2012, 07:45 PM   #24
Replaced all 8 with motorcraft platinum, replaced cap/button, runs better but still lopes after it sits hot and is started hot
Old 04-12-2012, 08:01 PM   #25
i would start looking at the pip and coil. sometimes with changing temperatures ignition parts may start acting funny when they are getting weak.you can test both of these parts.if you still have a factory coil i would suggest upgrading to msd anyways.they are pretty cheap.
Old 04-13-2012, 07:37 AM   #26
While your at it. If u have access to them. I would check the timing and the fuel presure. By the sounds of your problems. It sounds like it could be missing just a tad makin it sounds like it's loping. Run u some good Lucas fuel treatment. U could have a injector that's starting to get cloged. But prolly not but u never know with problmes like thst. Btw how many miles on r your car ?
Weird idle eouellette18 2005-2010 Mustang GT 7 05-10-2012 08:04 AM
Weird noise under glove box Blackedout Pre-2005 V6 Mustang 15 03-24-2012 05:53 PM
Anyone ever had a weird whistling sound GE3G 2011-2014 Mustang GT 7 03-23-2012 11:57 AM
Weird noise when start up? 96 stang SVT Mustang 9 01-13-2012 05:25 PM
engine acting weird Kamakanani0 Pre-2005 V6 Mustang 6 01-05-2012 09:08 PM
04:37 AM
