Waterpump gasket - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 1979-1995 Mustang GT
Closed Thread
Old 04-09-2012, 04:51 PM   #1
Beastynotch is unknown around these parts
Waterpump gasket
I have an aluminum water pump on my 88 coupe and I think it has a tiny leak in the gasket. Should I replace the whole water pump or just the gasket? Car has no cooling issues what so ever but just has a really small drop when it's cold, I think when it heats up it might actually stop leaking.
Beastynotch is offline
Old 04-09-2012, 05:10 PM   #2
Senior Member
Trojan Horse is just getting started.
Re: Waterpump gasket
Check the weep hole on the under side of the shaft support.
If it is leaking there it is time for a new pump.
Trojan Horse is offline
Old 04-15-2012, 12:27 AM   #3
Nicolosi11480 is unknown around these parts
also check the backside of the elbow hose for a small puncture or hole,it has happened to me on a 5.0 explorer already.installed a water pump didnt remove the hose from the engine so i just stuck it on topped it off cranked it up then i found the real culprit.if you gotta pull the pump and you got a few bucks to spend maybe itll be worth it to buy a better water pump. in my opinion at least replace that elbow hose since water pump is coming off anyway.
Nicolosi11480 is offline
Old 04-15-2012, 10:08 AM   #4
Thanks for the info guys. I'm hoping to have my custom cam in by the end of summer so I'm thinking I'll probably just wait til then to do anything with the water pump. It's not a big leak at all, only left about a half dollar size spot on the driveway after 4/5 days and coolant is still full. Thanks.
Old 04-15-2012, 08:34 PM   #5
i agree with that.might as well wait and kill as many birds with the same stone ya know?
Old 04-15-2012, 09:53 PM   #6
Senior Member
That will work, IF the leak doesn't get worse, which they are inclined to do over time.
If it's a gasket then the pressure blowing past it is going to keep eating away at it.
If it is the internal pump shaft seal, the rotation of the pump is going to progressively make it worse.
I'd fix it so it didn't leave me stranded somewhere or overheat and ruin my engine.
Old 04-15-2012, 10:01 PM   #7
Moderator
93slowstang's Avatar
93slowstang is unknown around these parts
+1. And when it comes time for the cam you won't have to take it back off. It will stay attached to the timing cover.
93slowstang is offline
Closed Thread
07:57 PM
