04-10-2012, 07:35 AM
#1 | | Registered User
| Taurus electric fan
Have a Taurus fan I got off my buddy for free i was wondering if it is enough to cool my car?
2004 mach 1(totaled=() 93 mustang lx white
Gt40x heads,e 303 cam, Ford racing 1.6 roller rockers, cobra upper and lower intake, ram air intake, c&l bigger maf, 30lb injectors, Bbk fuel Pressure regulator, double roller timing chain,Bbk shorty headers & h-pipe,flowmasters cat back,chipped,t-5 swap king cobra clutch, 4.10 gears. |
04-10-2012, 08:17 AM
#2 | | Senior Member
You need close to 2500 cfm to properly cool.but I have had good luck using most factory type electric fans on different models.usually the propblem is when you get a cheap off the shelf type.just make sure it covers most of your radiator.
Summit racing sells really nice fan controllers.they come with hd relay,water sensor with adjustable controller to help dial in the exact temp you want your car to run at.they are around 45$. If you want the part number let me know cause that is what I use.
04-10-2012, 09:05 AM
#3 | | Registered User
| Quote: |
Originally Posted by dreamstang You need close to 2500 cfm to properly cool.but I have had good luck using most factory type electric fans on different models.usually the propblem is when you get a cheap off the shelf type.just make sure it covers most of your radiator.
Summit racing sells really nice fan controllers.they come with hd relay,water sensor with adjustable controller to help dial in the exact temp you want your car to run at.they are around 45$. If you want the part number let me know cause that is what I use. | I'd lik the part number was gonna get a spal fan controller but they r discontinued
04-10-2012, 09:15 AM
#4 | | Senior Member
This is it
04-10-2012, 09:21 AM
#5 | | Senior Member
05-07-2012, 04:37 PM
#6 | | Registered User
| Quote: |
Originally Posted by dreamstang | Where did u put the sensor at? Did u have to drill a hole somewhere?
05-07-2012, 04:45 PM
#7 | | Registered User
| Re: Taurus electric fan
here is a short cut on a excellent way to wire up a Taurus fan. 2-Speed FORD TAURUS fan wiring dia. and part list - HybridZ
What is best in life?
To crush your enemies
See them driven before you
and hear the lamentations of thier women
05-07-2012, 04:46 PM
#8 | | Senior Member
i put it on my water outlet ( thermostat) housing. i had an extra plugged hole there. i wouldnt put it on the intake because it would be reading engine water temp and not radiator water temp. so either there or if you have a plugged hole on the radiator would work.
05-07-2012, 04:52 PM
#9 | | Registered User
| Quote: |
Originally Posted by dreamstang i put it on my water outlet ( thermostat) housing. i had an extra plugged hole there. i wouldnt put it on the intake because it would be reading engine water temp and not radiator water temp. so either there or if you have a plugged hole on the radiator would work. | What was the hole originally for? Or do u remember
05-07-2012, 04:57 PM
#10 | | Senior Member
i am not sure if something was there originally or not. my car is carbed so the whole engine compartment is completely different than stock. but the original housing that was on there (which had the hole) was not theright housing. it was angled at 45* where the hose attached. so i bought a 90* housing off ebay pretty cheap and it also had the hole.
05-07-2012, 05:20 PM
#11 | | Moderator
| Quote: |
Originally Posted by Jettin Stang
What was the hole originally for? Or do u remember | It's probably to bleed air out of the cooling system.
05-08-2012, 03:04 AM
#12 | | Registered User
Just to throw it out there I am using a dual puller fan off of a v6 contour. Works great.
05-08-2012, 06:26 AM
#13 | | Registered User
| Quote: |
Originally Posted by 93slowstang
It's probably to bleed air out of the cooling system. | If so will it work w the ac being hooked up
05-08-2012, 08:39 AM
#14 | | Registered User
Did any of you guys have to change to a higher amp alternator?
05-08-2012, 09:00 AM
#15 | | Registered User
| Quote: |
Originally Posted by Meansaleen Did any of you guys have to change to a higher amp alternator? | Yes I use a 130 amp alternator. The stock alt is only 90amp or so and isn't enough juice. Check out pa performance they sell alts and kits to convert them there are also junkyard options but I can't remeber which has what. You'll need the alt and a wiring kit. Its pretty simple and works great.
05-08-2012, 09:22 AM
#16 | | Senior Member
I use a 150 amp with full msd system.
05-08-2012, 02:31 PM
#17 | | Registered User
I have a 200 amp
05-08-2012, 07:13 PM
#18 | | Moderator
130 amp off a 95 gt.
