3.73 gears??? Need help - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 1979-1995 Mustang GT
Closed Thread
Old 04-10-2012, 08:58 AM   #1
sixpac's Avatar
sixpac is unknown around these parts
In my 5.0 manual I was told I have 3.73 gears witch I believe is true. It sound weird but I feel first gear when I'm driving is completely pointless. It seam I hit like 5-mph an have to shift the rpms get up there so high. I find myself starting in second almost allll the time. I don't like I feel like I'm driving a 4 speed. What can I do? Different gears? Different????
Horse Power sells cars, Torque Wins Races.
2001 Mustang GT 4.6..
sixpac is offline
Old 04-10-2012, 09:06 AM   #2
Robbie94gt is unknown around these parts
It seems like u might have 4:10s. What is your rpm at 60 in 5 gear just crusin?
Robbie94gt is offline
Old 04-10-2012, 09:11 AM   #3
Senior Member
dreamstang is unknown around these parts
I would pull the numbers off the tranny id tag and see what tranny is in there.because 4 cylinder trannys have a shorter 1st gear.and also you can check your gear ratio pretty easily if you want.all you have to does is support the rear end of the car up in the air.mark the tire and the drive shaft.turn the drive shaft until the the tire makes one full revolution while counting the drive shaft revolutions.
Imo I like the hard launching short first gear.but that's just me.if you have the proper trans then your only option is lowering the gear ratio.
dreamstang is offline
Old 04-10-2012, 09:17 AM   #4
sixpac's Avatar
I'll have to check its getting glass put in it soo.
---------- Post added at 10:17 AM ---------- Previous post was at 10:14 AM ----------
Well the cops around here hate loud cars and things like leaving a little rubber on the ground. So I don't like the launch. The 4cly tran bolts on to the 5.0? If I don't have 3.73 gears would your recommend them?
sixpac is offline
Old 04-10-2012, 09:20 AM   #5
stampde's Avatar
stampde is unknown around these parts
Re: 3.73 gears??? Need help
jack up the rear , mark the driveshaft
then mark the tire , spin the tire 1 revolution and count how many times the drive shaft makes a complete rev , that'll be your gear ratio
1 spin of the tires , 3 3/4 spins of the drive shaft would be about a 3.73 ,if it goes slightly over 4 spins you have 4.10's etc .....
2006 Tungsten grey v6 Pony package
stampde is offline
Old 04-10-2012, 09:24 AM   #6
Senior Member
Yes the 4 cyl trans bolts right up.I think all that's needed is a different pilot bearing.a lot of people use them but they are a little weaker.
Old 04-10-2012, 09:29 AM   #7
sixpac's Avatar
Well I haven't drove a lot of 5.0s but it seams to have a lot of power in the trans but I'll see if I can pull the numbers soon.
sixpac is offline
Old 04-10-2012, 09:53 AM   #8
Senior Member
There are very similar trans.but they have a little different gearing.just a thought that's all.
Old 04-10-2012, 10:48 AM   #9
sixpac's Avatar
What gears would you recommend I like low cruzing speeds as it is not a daily driver but I don't want it to be topped out at rpms at 80mph. I hope I'm making sense. Like power but I like to Cruz I want a good average gears 3.73 good for that?
sixpac is offline
Old 04-10-2012, 11:01 AM   #10
Senior Member
3.73 is a very popular gear.you shouldn't have any problem on the highway if that's what you have, besides a 1-2 mpgs.
Closed Thread
03:38 PM
