starting issue - Mustang Evolution
Old 04-10-2012, 03:40 PM   #1
351mustanggt's Avatar
starting issue
so guys this morning i went to start my car and it cranked like normal but for some reason would not fire. i hit the smog pump with a wrench and when i tried to start it again it fired right up.
yes i know hitting smog pump has no chance of being wat caused it to fire, but tellin everything that happened
---------- Post added at 04:40 PM ---------- Previous post was at 04:39 PM ----------
any ideas on watsup? battary and terminals were fine
351mustanggt is offline   Reply With Quote
Old 04-10-2012, 03:52 PM   #2
First is it getting fuel or spark?
Old 04-10-2012, 03:55 PM   #3
i assume so since it drove normal when it finally started.
Old 04-10-2012, 03:59 PM   #4
duh.lol i guess it would be. hmmm....
Old 04-10-2012, 04:44 PM   #5
Filibuster
Did you notice if the fuel pump primed when you turned the key to the on position?...maybe a finiky pump relay?..
XXSTEVEO66 is offline   Reply With Quote
Old 04-10-2012, 04:51 PM   #6
didnt notice but will keep that in mind
Old 04-10-2012, 05:30 PM   #7
Re: starting issue
Maybe a loose or bad wire that you jarred when you smacked the smog pump?Check your engine ground wire for one.
Old 04-10-2012, 05:33 PM   #8
other weird part is that its started multiple times without problems.
Old 04-10-2012, 05:35 PM   #9
I would suggest keeping that wrench with you just incase.
Old 04-10-2012, 05:37 PM   #10
i shall call it lucky wrench
Old 04-10-2012, 05:42 PM   #11
Re: starting issue
The cure for all those idiosyncrasies a vehicle can have.
Old 04-10-2012, 06:31 PM   #12
Filibuster
Lol!...+1
Old 04-11-2012, 06:11 AM   #13
so it sounded like the fuel pump didnt prime as itnormallydoes
---------- Post added at 07:11 AM ---------- Previous post was at 07:10 AM ----------
im guessing relay since after the car finally starts and its ran the prime does normal
Old 04-11-2012, 07:43 AM   #14
Bane-'s Avatar
Re: starting issue
Replace the relay an call it a day just had to do it with my fox, would turn car off but relay would stick open having it continuously pump fuel lol exact opposite as your problem 15 dollar relay at advance
Old 04-11-2012, 07:49 AM   #15
Sounds like a good place to start.
Old 04-11-2012, 11:56 AM   #16
switched the relay out guess ill find out tomorrow if it solved it
Old 04-12-2012, 08:41 AM   #17
seems to be fixed thanks everyone for your input
Old 04-12-2012, 10:44 AM   #18
Filibuster
Awesome!..
Old 04-12-2012, 11:01 AM   #19
Sweet! Glad to hear.
03:11 PM
