Gt40 upper and lower intake - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 1979-1995 Mustang GT
Closed Thread
Old 04-10-2012, 07:37 PM   #1
Gary100288's Avatar
Gary100288 is unknown around these parts
I was wondering wat difference will I tell if I take my stock upper and lower intake off and replace it with the gt40
Gary100288 is offline
Old 04-10-2012, 08:00 PM   #2
Senior Member
Trojan Horse is just getting started.
Re: Gt40 upper and lower intake
Maybe a 10-20 hp difference.
Trojan Horse is offline
Old 04-11-2012, 07:58 AM   #3
Titus Wadicus
svtlx's Avatar
svtlx is unknown around these parts
maybe 10hp with a 65-70mm throttle body. 2-3hp if you use your stock throttle body...imo
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
svtlx is offline
Old 04-11-2012, 03:07 PM   #4
Moderator
93slowstang's Avatar
93slowstang is unknown around these parts
+1, not going to do too much good with out other supporting mods.
93slowstang is offline
Closed Thread
03:32 PM
