Alternator squeals? Help! - Mustang Evolution
Old 04-10-2012, 10:51 PM   #1
slow281
sixpac's Avatar
Region: Nebraska
It squeals like I have a bad belt but it doesn't swam to be week or anything. Belt too tight ect? I unplug it and it stops the noise.
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 04-11-2012, 07:46 AM   #2
Titus Wadicus
svtlx's Avatar
Re: Alternator squeals? Help!
i think you need a new alternator... typicaly a whine or squeal indictes a load on the alternator...
sometimes it can happen if the alternator gets wet and gets sum rust on the windings or magnet.
but it sounds like its on its way out, and you need a new one. jmo....
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 04-11-2012, 01:59 PM   #3
+1 I agree.
Old 04-11-2012, 06:45 PM   #4
aegischief's Avatar
Replace the alternator. Sounds like a bearing going bad. It is going to fail on you at the least opportune time.
aegischief is offline   Reply With Quote
08:14 AM
