Moog rear lower control arm bushings - Mustang Evolution
Old 04-11-2012, 03:43 PM   #1
bigcolt45's Avatar
I boxed my rear lower control arms and welded in ride height adjusters . And none of my local parts store show the lower bushings at all. I was hoping somebody could throw me some moog part numbers or anything they could cross-reference . Thanks
bigcolt45 is offline   Reply With Quote
Old 04-11-2012, 03:50 PM   #2
I did a pretty thorough search.even on there website.it seems they only make front bushings for our cars.
Old 04-11-2012, 04:34 PM   #3
bigcolt45's Avatar
Or any "name" brand
Old 04-11-2012, 05:05 PM   #4
Bane-'s Avatar
Re: Moog rear lower control arm bushings
Upper and lower rear - 1989 - MUSTANG - FORD - Control Arm Bushings and Bearings - Bushings & Mounts - Chassis & Suspension - SummitRacing.com see if that works, should bring up everything on summit with upper/lower rear bushings.
Old 04-11-2012, 07:24 PM   #5
bigcolt45's Avatar
I will give it a shot . I was hoping for something I could pick up
More local. Track night is 2 days away
Old 04-11-2012, 07:26 PM   #6
any local speed shops? they usually cary that kind of stuff
---------- Post added at 08:26 PM ---------- Previous post was at 08:26 PM ----------
where are you located?
Old 04-11-2012, 07:49 PM   #7
bigcolt45's Avatar
Tampa,fl
Old 04-11-2012, 08:22 PM   #8
i didnt find much in your area.i did see orielys in your area i think . they carry bushings, but im not sure on store availability or special you will have to call for availability
http://www.oreillyauto.com/site/c/se...1988&make=Ford
these are they colsest stores.
http://www.oreillyauto.com/site/fi/cities/FL.oap
Old 04-12-2012, 08:03 AM   #9
I would replace the entire lower control arm, leave the uppers (as with stiff bushings they can create bind issues when flexing side to side vs a full squat of the rear)
replace the uppers with OEM if worn though
I would go Delrin vs Poly for bushing material~ check with maximum motorsports, if you are only interested in traction in a straight line lift bars can do great things but at the price of handling
Old 04-12-2012, 10:30 AM   #10
bigcolt45's Avatar
I know new would work . But I boxed the lowers and welded in ride height adjusters . To give it some personal flair. I was shooting for kind of an old school touch. I was just hoping somebody else ran into the issue of no local parts store showing the bushings. And didn't know if any other bushings would work. Thanks
---------- Post added at 04:30 PM ---------- Previous post was at 04:06 PM ----------
Like possibly the fronts fitting or a bushing off a different year or car.
06:48 PM
