Steering wheel - Mustang Evolution
Old 04-11-2012, 10:49 PM   #1
Kenny laird's Avatar
Steering wheel
As try to put a aftermarket wheel on my mustang i have airbag wheel its a 93. Every were i check says they dont make adapter for my steering colum Guess ill have to put a tilt colum in so i can get a adapter to use diffrent wheel. I find it hard to believe i cant get a adapter to work on my car without changing the wholle steering colum
Kenny laird is offline   Reply With Quote
Old 04-12-2012, 07:57 AM   #2
Re: Steering wheel
not sure on what you can do but just a major FYI if you carry insurance on the car and you remove the air bag that can cause big trouble if you file a claim~
Old 04-12-2012, 10:13 AM   #3
Its a 89 it didnt come with airbag the guy i bought from put a airbag colum from a93 but thanks
Old 04-12-2012, 08:32 PM   #4
Jettin Stang's Avatar
Grant makes an adapter...I don't have a tilt column on mine n I'm bout to install my aftermarket steering wheel
Jettin Stang is offline   Reply With Quote
Old 04-12-2012, 08:34 PM   #5
i sont have a tilt wheel either. i have a grant steering wheel mine.
Old 04-12-2012, 09:50 PM   #6
Were would i find the adapter summit says they dont make one
Old 04-12-2012, 10:21 PM   #7
Wheel im tryn to use
Old 04-12-2012, 10:22 PM   #8
Pic of my car just for the hell of it
Old 04-13-2012, 05:30 AM   #9
I got my adapter at autozone.
Old 04-13-2012, 08:00 AM   #10
I bought mine from o'reilys
Old 04-13-2012, 10:24 AM   #11
Thats weird couse ive talked ti both of them amd they both said they cant get them for the mustang with airbag
Old 04-13-2012, 10:26 AM   #12
I don't have an airbag.sorry
Old 04-13-2012, 11:33 AM   #13
Re: Steering wheel
The columns are made differently, internally to provide the circuits for the airbag controls.
You will probably have to change out the column.
Steering wheel manufacturers will not provide wheel adapters for air bagged cars because it makes them liable in the event of an accident.
Old 04-13-2012, 11:42 PM   #14
Ok thank u. Been movn this tilt colum around for a while guess its time to put it in
Old 04-18-2012, 07:45 PM   #15
So I took the stock wheel off and went to install the grant adapter and it has slpines in it but the stem on my car doesn't....do I nd to buy a different adapter? Or something else? Here's some pics
ID:	47548   Click image for larger version
Old 04-19-2012, 07:40 AM   #16
Re: Steering wheel
You will have to get an adapter to fit the column shaft that you have.
Don't be tempted to cobble something up, because your safety and life may depend on it.
Old 04-19-2012, 11:27 AM   #17
Do uk where I can find something that would hit it.....and no I wouldn't just throw something together so i could fit the steering wheel
Old 04-19-2012, 12:08 PM   #18
Re: Steering wheel
If the wheel manufacturer does not make them, then you are probably out of luck.
Old 04-19-2012, 04:44 PM   #19
Can I change the steering column? N if so how hard is that
Old 04-19-2012, 06:59 PM   #20
Re: Steering wheel
Sure you can.
It's not too difficult.
For me it was always the wiring that was the biggest PITA, especially if it doesn't match the car.
I would suggest you see if the procedure is covered in your Chilton's or Haynes manual in case you have any issues.
Old 04-20-2012, 08:54 AM   #21
Sure you can.
Where exactly would I get one at
Old 04-20-2012, 11:06 AM   #22
Re: Steering wheel
Salvage yard or an individual with a wrecked car.
Old 04-21-2012, 08:47 AM   #23
What yr would I look for? Cuz wouldn't they have to not have a air bag
Old 04-21-2012, 09:22 AM   #24
Pete Jones
90mustangLX's Avatar
Send a message via ICQ to 90mustangLX Send a message via AIM to 90mustangLX
87-88 didn't have airbags if I remember correctly, the older ones didn't either but I would try to stay as close to your year as you can for the column
90 LX hatchback
(sold but not forgotten)
89 LX Notchback
No motor/trans (for now)
90mustangLX is offline   Reply With Quote
Old 04-21-2012, 03:49 PM   #25
Ok thanks well mines a 91
08:00 PM
