94 gt 5.0,whats going on here? - Mustang Evolution
Old 04-12-2012, 01:42 PM   #1
justjake94boss's Avatar
What is this device, and where is that crimped copper tube go??
justjake94boss is offline   Reply With Quote
Old 04-12-2012, 02:11 PM   #2
That's the egr vavle tube that originally went from the egr to the header. Somebody has cut it off. It looks like it prolly leaks a little. What I did on mine was take the nut off take the pipe out and put three pennys in the nut and screw it on. It sealed up real nice
Robbie94gt is offline   Reply With Quote
Old 04-12-2012, 02:14 PM   #3
Re: 94 gt 5.0,whats going on here?
That's your EGR valve and that tube went into your exhaust header.
Old 04-12-2012, 02:20 PM   #4
So does this mean they replaced the headers with after market headers, and whould this thro a code
Old 04-12-2012, 02:38 PM   #5
Yes and yes it can.
Old 04-12-2012, 02:48 PM   #6
What is the purpose of doing this? And what pros and cons does it have?
Old 04-12-2012, 07:09 PM   #7
It just seals it up real nice without having to weld it up. And I bet u have at least a little exhaust leak where it's crimped at on your passenger side header does it have a threaded bung on it with a nut on it
Old 04-12-2012, 08:27 PM   #8
After taking it off, that tube is welded on the end, I put a penny in it anyway and tightend it back up, nope don't see any bungs or fittings on the header, after a test drive no check engine light
Old 04-12-2012, 08:29 PM   #9
it must have an egr eleminator.
Old 04-13-2012, 12:25 AM   #10
If it isn't causing any issues fab up or buy a block off plate and remove it.
Old 04-13-2012, 07:22 AM   #11
I have my pipe unhooked but I have the egr valve connector still hooked up to the egr and the check engine light never came on. The other day I unhooked the vacuum line that plugs up on the egr and capped both ends and now the check engine light comes on. I just figured I would throw that out there !
Old 04-13-2012, 07:32 AM   #12
Ya my cel came back on too, so you have to get some resistors and put them in the wiring to trick the computer to thinking your egr is working, that will be my next lil project
05:00 PM
