86 gt ran perfect after new fuel pump and won't run now - Mustang Evolution
Old 04-13-2012, 10:08 AM   #1
lilrafe87's Avatar
Installed new fuel pump and drove it around for a little and parked it, now she won't stay running. Fires up and then dies right away. I'm guessing the new fuel pump is junk. It was cheap off Ebay, 18.00 bucks I paid for it. Think this might the problem? Thanks
---------- Post added at 11:08 AM ---------- Previous post was at 10:26 AM ----------
I also just used starting fluid and sprayed it into the throttle and she will run a little longer and I can give it gas, but dies. Really thinking my new fuel pump is trash.
lilrafe87 is offline   Reply With Quote
Old 04-13-2012, 10:17 AM   #2
That is possible.fuel pumps are one of those item you don't go cheap.
Also make sure you didn't kink any lines.
Old 04-13-2012, 10:57 AM   #3
lilrafe87's Avatar
Re: 86 gt ran perfect after new fuel pump and won't run now
Positive the lines are not kinked. Just dont understand how it ran perfect and then I let it sit for about an hr and now she won't stay running. I can hear the pump prime, but I've had a GMC Jimmy that would prime, but not start until I sprayed starting fluid in the throttle and it fired right up. Im going to invest in a new fuel pump asap. Any good ones I should look into? Thanks again for the input
Old 04-13-2012, 11:01 AM   #4
A walbro should be good enough.not eBay cheap but not to pricey.
You can try running a jumper wire and ground straight to the pump, bypassing everything and see if its working.
---------- Post added at 12:01 PM ---------- Previous post was at 11:59 AM ----------
And/or check fuel pressure.
Old 04-13-2012, 05:53 PM   #5
lilrafe87's Avatar
Found a walbro 255lph for 99 bucks online. Can I use the 255lph on my stock 86? Thanks
Old 04-13-2012, 06:55 PM   #6
you can. but i would recommend a 190. you will still have room to grow with the 190. with the 255 you maybe recirculating the fuel alot.
Old 04-13-2012, 07:58 PM   #7
lilrafe87's Avatar
Figured that would be an issue
Old 04-13-2012, 10:27 PM   #8
tc x 4's Avatar
I wouldn't use starting fluid on a gas engine, unless its a briggs&stratton. Will lock your motor up .
Old 04-14-2012, 03:34 AM   #9
Filibuster
Ditch the ebay fuel pump n get you a new one!...then with fuel and spark I bet she runs just fine
XXSTEVEO66 is offline   Reply With Quote
Old 04-14-2012, 11:53 AM   #10
lilrafe87's Avatar
I'm getting a bbk fuel pump today and I will swap the junkie one out and hopefully that's the problem. Wish me luck.
Old 04-14-2012, 12:33 PM   #11
Good luck.
Old 04-19-2012, 03:09 AM   #12
lilrafe87's Avatar
Replaced the pump, runs good, but still shakes at idle even when parked. Hmmmmm
Old 04-19-2012, 05:53 AM   #13
86 5 speed vibrates when giving gas at idle <~ There's a start. Good luck.
All41 is offline   Reply With Quote
Old 04-19-2012, 03:09 PM   #14
lilrafe87's Avatar
The shaking I found out was the harmonic balancer. I could hear it hitting the pointer. Rubber also was peeling out from behind the balancer. Going to replace it this weekend. Hope all goes well, thanks
Old 04-20-2012, 10:10 AM   #15
lilrafe87's Avatar
Problem solved! Changed the harmonic balancer and now she has no vibration. Thanks guys
04:25 PM
