maf sensor - Mustang Evolution
Old 04-13-2012, 11:36 AM   #1
thomas91gt's Avatar
maf sensor
Anyone know what this is for F1ZF-12B579-AA? Or injector size?
thomas91gt is offline   Reply With Quote
Old 04-13-2012, 11:49 AM   #2
Re: maf sensor
Those were used on the 1990- 1995 Mustangs, Thunderbirds and Taurus.
It probably is calibrated for stock 19 lb injectors.
Here is the page I found them on.
Walbro MAF
Old 04-13-2012, 12:05 PM   #3
thomas91gt's Avatar
Ok thinks im having problems with my car i think it might be this. I have ran across this one. If u unplug it while its running should the engine respond
Old 04-13-2012, 12:21 PM   #4
Re: maf sensor
I have seen cases where the responses from unplugging them ranged from no change at idle to running rich or lean, or killing the engine.
It just depends on what other issues you might have I suppose.
Old 04-13-2012, 02:43 PM   #5
thomas91gt's Avatar
I replaced it with the anorher one still same thing i was getting an egr code i bypassed it using resistors in the diagrahm i got off here now theres no light but still runs the same. I have checked for vacuum leaks and found none guess im lookin at an iac or something.
Old 04-13-2012, 02:53 PM   #6
Re: maf sensor
The only thing the resistors do is to get rid of the CEL light for the EGR.
If the EGR is still attached and not functioning properly it can still cause you problems.
Try to better describe the issues you are having and we'll see what we can figure out.
Old 04-13-2012, 03:25 PM   #7
thomas91gt's Avatar
Right i took it off and put a plate on the intake... In the mornings i start it and unless i imediately give it gas it will go dead. When i take off it seems hesitate or it takes it a second for it to go when i press the gas. It idles steady only a lot lower than normal. It will idle around 700 for a couple mins then all the sudden it will drop to 500.
---------- Post added at 03:08 PM ---------- Previous post was at 03:08 PM ----------
O and running really rich i went 70 miles on a half of a tank lol
---------- Post added at 03:25 PM ---------- Previous post was at 03:08 PM ----------
Completely stock i just replaced the coolant temp sensor are there only one of them? i seen another one that looks like one right behind the temp sending unit
Old 04-13-2012, 04:06 PM   #8
Re: maf sensor
What about the IAT (Intake Air Temp) sensor?
I'm assuming you replaced the ECT (Engine Coolant Temp) sensor.
Make sure your fuel pressure isn't set to high.
Should be 38-40 psi at idle with the vacuum line removed from the regulator and the line plugged.
Also what condition are the injectors in?
Ever replaced the injector O-rings and pintle caps?
Old 04-13-2012, 07:19 PM   #9
thomas91gt's Avatar
Yea i replaced the ect is there only one i seen another that looks like like one. Where is the ict i havnt seen it. Yea i have to get a pressure tester for the fuel
Old 04-13-2012, 09:00 PM   #10
Re: maf sensor
What is an ICT?
Old 04-13-2012, 09:02 PM   #11
thomas91gt's Avatar
Sorry iat
Old 04-13-2012, 09:43 PM   #12
Re: maf sensor
Sorry iat
It is located in the intake tube near the MAF.
Google search IAT sensor for your year car and look at the images.
That will provide you with a visual reference.
Old 04-14-2012, 09:46 AM   #13
93slowstang's Avatar
On the foxes it's in the #5 runner on the lower intake.
Old 04-14-2012, 04:27 PM   #14
Re: maf sensor
Well "smack my head and call me smiley".
You are correct, sir.
Mine has been moved to the MAF intake tubing like on the 95's and I never realized it was not in its factory location.
Old 04-14-2012, 04:59 PM   #15
thomas91gt's Avatar
Lol i thought so i new it wasnt in the tubing ha. I think i about have it figured out still doesnt seem to run like it should i believe it was a timing issue my bolt had worked loose on me. I think it still needs something tho doesnt have the power that it should. A friend has a set of lightning heads of a 93 would those be worth putting on he doesnt have the intake tho
Old 04-14-2012, 05:03 PM   #16
Lol, figured you had a brain fart . Also its called the act- air charge temp sensor in most apps incase the auto store can't pull up iat.
Old 04-14-2012, 05:04 PM   #17
those are 351 heads? if so then no you wouldnt benefit.
Old 04-14-2012, 05:07 PM   #18
They are gt40 heads.
---------- Post added at 06:07 PM ---------- Previous post was at 06:06 PM ----------
Yes they'll improve performance some but not like a set of aftermarket heads. If they're cheap enough go for it.
Old 04-14-2012, 05:07 PM   #19
thomas91gt's Avatar
Yea i was thinking the same more trouble than its worth
Old 04-14-2012, 05:09 PM   #20
Ahh. Then yes I agree with this. ^
Old 04-14-2012, 05:16 PM   #21
If you get them dirt cheap have them ported and get a valve job and you'll have a nice set of heads that perform very well cheaper than a few aftermarket heads.
Old 04-14-2012, 05:47 PM   #22
thomas91gt's Avatar
Yea they want to much for them 400 lol
Old 04-15-2012, 09:26 AM   #23
thomas91gt's Avatar
Well it runs better since i set the timing on it but it is still extremely cold natured it doesnt want to run at all in the morning. I wonder if its not an intake leak or a head gasket blown between cylinders
Old 04-15-2012, 10:51 AM   #24
You may need to try resetting your idle. Mine was cold natured and resetting the idle help a lot
Old 04-15-2012, 09:00 PM   #25
thomas91gt's Avatar
Ill try it tomorrow... Gonna try to do a compression check and fuel pressure check
Old 06-04-2012, 10:27 AM   #26
thomas91gt's Avatar
I tried to reset it. Didnt really help i has gotten worse... Now it wont hardly spin the tires in the rain lol I really think its a head gasket. I think its blown between the cylinders i had an 86 do the same thing and thats what had happened. this just gives me a reason to upgrade lol
11:42 PM
