Horsepower from upgrades - Mustang Evolution
Old 04-14-2012, 07:39 AM   #1
captain78's Avatar
Just curious but does anyone know what kinda horsepower you can hope to gain by the upgrades you have. TB CAI long tubes intake heads cam injectors. Smog delete. And so on. I sure it won't be dead on without a dyno just curious as to what imma be looking at
---------- Post added at 08:39 AM ---------- Previous post was at 08:18 AM ----------
Just a list of my soon to be installed up grades
Trickflow track heat upper and lower. 75mm TB. BBK in finder CAI. 24lb injectors. 75mm MAF custom ground cam. AFR 165 heads 1.6 RR. Long tube headers. Egr delete. Smog delete. BBK fuel rails. Bbk fuel regulator and pressure gauge. 255lph fuel pump. 200amp alt. Working AC. And I know they say 225hspr stock and guessing thats flywheel not rear wheel Just trying to get a good rough estimate.
captain78 is offline   Reply With Quote
Old 04-14-2012, 09:06 AM   #2
Yes the stock 225 is flywheel. Yes its really hard to guess as all combos work different with each other.but I'm gonna guesstimate 300-325 to the wheels.
Old 04-14-2012, 10:04 AM   #3
captain78's Avatar
Guess imma have to take it to the dyno to get real numbers
Old 04-14-2012, 10:19 AM   #4
That would be awsome. I am curious be cause I almost got those heads.I also want to dyno.
Old 04-14-2012, 10:35 AM   #5
captain78's Avatar
Well I got them because there good for 100 hspr according to the magazines. With just heads 1.7 rockers and long tubes a stock block 302 makes 400 hspr
---------- Post added at 11:35 AM ---------- Previous post was at 11:32 AM ----------
405 @6200 RPMs to be exact. With a carb.
Old 04-14-2012, 10:47 AM   #6
Well your stock up is 225. Figure in 17% drivetrain loss. That puts you stock rwhp around 187. So if you get 325 at the wheels I would consider that excellent.that is well over 100 up gain. What mm&ff did with that motor was astounding! Imo not everyone will get the same results.but if they did that would be great.I like to expect low. Then when you do better than that, it makes you feel way better. But hopefully since you used similar parts they did you will reach great power.
Old 04-14-2012, 10:57 AM   #7
captain78's Avatar
I hope so if not lol that's why they make 331 stroker blocks and superchargers lol
Old 04-14-2012, 11:01 AM   #8
Haha. That is exactly why they do.
I don't know what my car makes but I am hoping for similar numbers that I told you.I have tfs heads, b303 cam,1.72 rr, 670 carb, weiand stealth intake.I actually chose this intake because of that article you mentioned. But anyways I do know 1 thing for sure.whatever my numbers are, my car is a whole different animal since the upgrades and I am very happy.I'm sure you will be to. At least for know.
Old 04-14-2012, 11:08 AM   #9
captain78's Avatar
Yea I just looked up what ford claimed for my car when first made 14.4@96mph. Since I have no base line for my car cause everytime I plan to go to track it rains lol. So I'm curious as to what it will do with the 3:73s that are goin in today and I advanced my timing a bit and took out the air box thingy in finder.
Old 04-14-2012, 11:31 AM   #10
cgarray17's Avatar
Haha ya i was going to go your rout till i found a blower for cheaper then the heads so we will see just need to install it but ya dyno is the only true way to tell power numbers and also all dynos will give slight different numbers. But i bet just like mine you will see a biggg difference haha
94 GT Convertible
Current- Stock long block 118k, MAC CAI, 75mm Pro M MAF, PP 70mm TB,BBK shorties,BBK O/R H, Magnaflow catback, KING cobra clutch, 3.73 Gears
Soon to be Vortech blown with a built 306 Numbers and times to follow!!!
cgarray17 is offline   Reply With Quote
Old 04-14-2012, 05:07 PM   #11
Re: Horsepower from upgrades
I think you are definitely looking at a 100+ HP increase.Exact would be hard to pin down, because every engine is different even if built identically to another.
Sometimes the little stuff can trip you up, so pay attention to the smallest details when assembling.
Old 04-14-2012, 05:17 PM   #12
captain78's Avatar
what kinda little stuff TH. I have a chip but I was told because it was set for stock eng. And it was done back in early 90s. I was told to remove it for sure. And run without until I get a new one.
Old 04-14-2012, 05:20 PM   #13
I'm not sure what chip you have or if its cost efficient.but you maybe able to have it reprogrammed.if you get it dynoed you may need a particular chip for the technician. I would contact the speed shop that you plan on using if you do get it dynoed and ask them.
Old 04-14-2012, 05:22 PM   #14
captain78's Avatar
Dunked? Lol you mean dynoed lol. I'll do that. For sure then
Old 04-14-2012, 05:24 PM   #15
Yeah I edited it. Lol. Stupid auto correct.
Old 04-14-2012, 05:25 PM   #16
captain78's Avatar
Hell lol I'm not sure what chip I have. Lol I don't even know where to look guy I bought it from just told me it had one
Old 04-14-2012, 05:28 PM   #17
I'm not sure.I have a carb so my tuning is done with a flathead screwdriver.lol.but I would guess on the computer which is located under the passenger side kick panel under the dash.
Old 04-14-2012, 05:32 PM   #18
captain78's Avatar
Good to know I thought it was behind the radio
Old 04-14-2012, 06:06 PM   #19
Little stuff like:
Port matching and making sure gaskets do not protrude into the openings.
Bolt torquing values and sequences.
Clean out any "casting flash" in the intake and heads.
Make sure all sensors/controls are properly cleaned, set or adjusted.
Make sure timing and fuel pressure are set correctly.
Injectors clean, working and spraying properly. (I did this by fabbing an adapter for a can of carb cleaner to fit over the injector inlet and using a momentary switch to power the injector from the battery.)
Make sure the injector O-rings and pintle caps are in good shape and sealing properly.
Mainly any small detail that you might be inclined to over look or forget about because it appears to look ok or be working ok.
dreamstang is correct. Any chip will be plugged into the computer located behind the PS kick panel.
When/if you remove it be sure to cover the hole with tape or something to keep moisture and dirt out.
05:54 PM
