Dyno results :-( - Page 2 - Mustang Evolution
Old 04-17-2012, 07:04 PM   #36
Re: Dyno results :-(
There are so many possible variables that it would be difficult to pin down the exact cause.
Lower compression could be one major difference.
Driveline efficiency another.
Make copious notes of each car's mods and differences and compare them maybe?
Old 04-17-2012, 07:12 PM   #37
ColeJohnson's Avatar
Originally Posted by Trojan Horse
Why not it is simple?
You take the power produced at the rear tires, multiply it by the 18% loss or .18 to find out how much power was lost, then you add that power back onto the RWHP to get an approximation of the FWHP.
By FWHP I assume he means BHP, horsepower at the crank, or flywheel horsepower. The math seems legit, although slightly generalized. Haha
Sorry for this later reply.. I wasn't aware there were more pages already. Lol.
2016 Comp Orange GT (current)
Old 04-17-2012, 07:20 PM   #38
Yes it is simple and generalized, meant only to give a rough estimate.
Old 04-17-2012, 07:34 PM   #39
NeedSomeMods's Avatar
I seriously thought it meant Front Wheel HP, which is what I normally see FWHP stand for... Fly Wheel HP makes MUCH more sense. Thanks for clearing that up! Trojan, it was my lack of understanding, not your math that was the problem.
2000 V6 - RIP
The '94 -
NeedSomeMods is offline   Reply With Quote
Old 04-17-2012, 08:01 PM   #40
Sorry man, sometimes I just assume that everyone knows what I'm talking about.
I never think about Front Wheel Horsepower.
To me it is always Flywheel Horsepower FWHP or Rear Wheel Horsepower RWHP.
Old 04-19-2012, 06:29 AM   #41
The only chips TRULY worth having are done on the car, using a chassis dyno. The others can be okay, but not all are. Many mail order chips are what you may call "on the ragged edge" and those often lead to overly rich, but more importantly, overly lean conditions. If you have access to any decent tuner, that's your best bet, $500-1000 or whatever. It's safer in the long run.
Originally Posted by XXSTEVEO66 View Post
So then roughly my car puts 189hp to the ground...
That was a fairly typical rwhp for a pushrod 5L HO in a Mustang. I saw 187-189 for nearly all stock versions(when there was a dyno in the shop- when there was a shop).
Originally Posted by Trojan Horse View Post
Usually 4th gear or whatever gear provides a 1-1 ratio I believe.
^^ Thiis, with a 5speed manual.
No matter what, the test is to be done in the 1:1 ratio gear. On many cars, specifically automatics, this is typically "3rd" gear. Most manuals are 1:1 in 4th. The latest Mustang 6spd manual has a 5th gear 1:1 ratio.
All41 is offline   Reply With Quote
Old 04-19-2012, 06:48 AM   #42
Thanks for the confirmation.
I was pretty sure that they used whatever gear it took to get the 1:1 ratio, but not 100% sure.
Old 04-20-2012, 05:49 PM   #43
WhiteCobra94's Avatar
I dropped the car off Wednesday and this morning had the car custom dynoed tune by (2nd street speed in Pa) with a 302 bored to 308 , HCI, full off-road exhaust the car dynoed at 304rwhp / 314ft/tq,
Old 04-20-2012, 07:39 PM   #44
jhagan1980's Avatar
There has to be something else done to my car that I don't know about if I'm pushing 364tq!
jhagan1980 is offline   Reply With Quote
Old 04-20-2012, 07:41 PM   #45
What setup do you have
Old 04-20-2012, 08:21 PM   #46
jhagan1980's Avatar
What I know of:
TB
Long tube headers
SCT chip with Dyno tune
O/R x pipe
Flowmasters
3:73 gears
C&L CAI
I'm running 266hp and 364tq so I must have something that the previous owner(s) have done that I'm not a where of.
Old 04-20-2012, 08:28 PM   #47
What I know of:
TB
Long tube headers
O/R x pipe
Flowmasters
3:73 gears
C&L CAI
yeah the hp is maybe a little over average with a good tune, but that torque seems pretty high.
Old 04-20-2012, 08:41 PM   #48
Heads and cam too?
Old 04-20-2012, 09:19 PM   #49
jhagan1980's Avatar
Heads and cam too?
Not that i know of. I know the heads are stock.
Old 04-20-2012, 09:20 PM   #50
Yea that's odd!!! Lol
Old 04-20-2012, 09:22 PM   #51
maybe the stockers have had work done?
Old 04-20-2012, 09:30 PM   #52
What about a 351 short block with stock 302 top end
Old 04-21-2012, 11:12 AM   #53
88fox's Avatar
I'm gonna end up with a 331 and stock heads :'(
88fox is offline   Reply With Quote
Old 04-23-2012, 04:22 AM   #54
That's pretty good. Depending on the cam specs, you may have made more or less. I've seen S/C'd Fox bodies reaching that power level in the past.
I wondered what was done because the torque number sounds way, way off as compared to hp.
What I know of:
TB
Long tube headers
O/R x pipe
Flowmasters
3:73 gears
C&L CAI
With these mods, I'd say there is definitely something odd going on here. With factory stock heads, you'll be lucky to get that much rwhp and the torque may be up there near what you're showing, but that's not common stuff. I'd have to say the heads have been ported, if not replaced.
Old 04-23-2012, 07:12 AM   #55
Forum Car Trader
90GTNovi2000's Avatar
You gained 100ft. Lbs over the hp.. That's wild with only 266hp.. For the guy who said he has seen s/c'd foxbodies with 320 rwhp..that's weak.. Any decent build supercharged should make 380+ easily
90GTNovi2000 is offline   Reply With Quote
Old 04-23-2012, 12:06 PM   #56
gqsmash's Avatar
That some serious torque over hp..that looks like what some diesel engine makes
gqsmash is offline   Reply With Quote
Old 04-23-2012, 12:43 PM   #57
Maybe the dyno itself isn't correct!!!
Old 04-24-2012, 12:09 AM   #58
jwhayne0001's Avatar
That's my guess
jwhayne0001 is offline   Reply With Quote
Old 04-24-2012, 12:18 AM   #59
jhagan1980's Avatar
Originally Posted by jwhayne0001
That's my guess
That's what your hoping for!
Old 04-24-2012, 12:23 AM   #60
Let's line em up
Old 04-24-2012, 12:54 AM   #61
jhagan1980's Avatar
Let's line em up
Sounds good
---------- Post added at 06:54 AM ---------- Previous post was at 06:32 AM ----------
We can take them to windy hollow dragstrip
Old 04-24-2012, 01:25 AM   #62
When's there open days?
Old 04-24-2012, 01:27 AM   #63
jhagan1980's Avatar
Website shows test and tune every Saturday
Old 04-24-2012, 03:06 AM   #64
Rm360's Avatar
There is variances in dyno's if you have another shop around you I would take it there and retest it
Old 04-28-2012, 09:32 AM   #65
You goof'd on the quote, but oh well.
You think 304rwhp is weak for a supercharged 5L? Well, it is, but with stock heads, you're not just seeing 380rwhp. That would require plenty of help. We're talking about a car that put about 188hp to the ground when stock, and maybe 256ish lb-ft on the torque... Adding a P1SC isn't gonna set the world on fire. Back when I started with these, nobody had a dyno and the superchargers weren't exactly refined. Gotta work with whatcha have...
Old 04-28-2012, 03:53 PM   #66
Forum Car Trader
Yes I think it is weak for a supercharged 5.0.. But very respectable for all motor... I understand stock heads.. But on 9psi of boost on my stock e7's just cleaned and polished with an e cam .30 kb pistons it made 460 rwhp 430 tq.. On3 turbo setup.. Just IMO I can make 450 with stock heads..
---------- Post added at 04:53 PM ---------- Previous post was at 04:48 PM ----------
Lol and yeah I messed up the quote.. But that being said with the proper build and today's technology 300rwhp mustangs are everywhere..
Old 04-28-2012, 09:35 PM   #67
The Mustangs I've seen at that power level were in the mid 1990's till around 2001... Things have come a very long way. A turbo will change things far more than a simple 1990's centrifugal supercharger on an otherwise stock 5L. I've never seen stock E7 heads on any car making even 350rwhp. If you can get 100 more, think of how well the tuning has come along. 450 certainly makes me think the dyno is happy.
PS .30 overbore... Must be MASSIVE pistons... I've used .030-.060, but that's tiny by comparison....
As for power on stock E7 heads... I wouldn't waste my time trying to break into the 300's on stockers. Just far too restrictive for me. Then again, I'd never really want a Ford square cam either. To each his own.
Old 04-29-2012, 06:28 AM   #68
Just to add a money wrench to the equation here: I have the 70mm on3 kit with a bone stock 91 5.0 and I got 294rwhp/407rwtq@ 8.65lbs. This was tuned professionally btw.
JayKranz is offline   Reply With Quote
Old 04-29-2012, 08:14 AM   #69
Forum Car Trader
Yep I had the same on3 kit on me 89' and no speedtek has the best dyno available in dfw... Although we cranked the boost up and blew it sky high... Go to on3performance.com they have stock junkyard motors with 180k miles running 400+ rwhp that made me buy the kit 2 yrs ago.. I upgraded my kit also... E7 heads do suck and restrict big time but with a good polish and matching them to the intake ports they flow well enough to hit 400.. Seen it done im about to attach a video once I can dig on my computer.. I have tons of proof but this is a new phone and old one is in the river somewhere..
---------- Post added at 08:59 AM ---------- Previous post was at 08:55 AM ----------
On 3 Performance 5.0 1986 – 1993 Mustang single turbo system, shipping daily. We developed this kit years ago and now countless cars are running and putting down the numbers. We have put together what we think is the best horsepower per dollar modification you can do to your Mustang. You can literally bolt this kit on and double the factory horsepower(Close to TRIPLE the torque). Most stock 5.0 motors will put down around 185 +/- rear wheel horsepower. Most stock head and cam 5.0’s cars are making around the 480-520 rear wheel HP range.
---------- Post added at 09:14 AM ---------- Previous post was at 08:59 AM ----------
I'm not saying you guys are wrong by any means but just my opinion I am young and have only built 9 foxbodies but I have seen 400+ on ****ty e7 heads it didn't last long though lol.. So if I were to do it again... I would definitely stay with the 9psi spring and conserve my motor and I would still have my 89
Old 04-29-2012, 09:10 AM   #70
Not a bad price for the kit.
tbonestang is offline   Reply With Quote
04:16 AM
