Dyno results :-( - Mustang Evolution
Old 04-14-2012, 01:49 PM   #1
jwhayne0001's Avatar
Dyno results :-(
Got 221 horse, 270 ft pounds, out of my 95 cobra with O/R h pipe, flowmasters, CNL cold air not what I was expecting and it ran very lean so I have to get an adjustable fuel pressure reg and tune
jwhayne0001 is offline   Reply With Quote
Old 04-14-2012, 01:59 PM   #2
cgarray17's Avatar
Dam then i bet my poor 94 GT is even less as i have same mods as u except the gt40 heads and intake. Untill i force some air in its lungs lol. But that dose seem low for a cobra??
94 GT Convertible
Current- Stock long block 118k, MAC CAI, 75mm Pro M MAF, PP 70mm TB,BBK shorties,BBK O/R H, Magnaflow catback, KING cobra clutch, 3.73 Gears
Soon to be Vortech blown with a built 306 Numbers and times to follow!!!
cgarray17 is offline   Reply With Quote
Old 04-14-2012, 02:06 PM   #3
That's power to the wheels not at the flywheel so it actually sounds about right. The torque on those motors where always decent by way under powered in the HP category. Now a days, you have to add FI to compete with any newer car. It's a shame that four door Acura & Nissan make that power in sedan ;(. Sad very sad
SNK3BTE04 is offline   Reply With Quote
Old 04-14-2012, 02:08 PM   #4
deadsp0t's Avatar
True story
That's unimpressive
Old 04-14-2012, 02:17 PM   #5
McNassty's Avatar
Next time ya got her on the dyno have em Diablochip her and give her a tune and you'll be happier. Cost me about $500 bucks but well worth it
McNassty is offline   Reply With Quote
Old 04-14-2012, 02:26 PM   #6
deadsp0t's Avatar
From everything I've read SCT is the preferred chip, but if it's being dyno tuned I guess it wont make a lot of difference.
That's unimpressive
Old 04-14-2012, 02:36 PM   #7
McNassty's Avatar
SCT is fine but I thought that was a pre-programmed chip. The shop I go to uses Diablo programmers and chips
Old 04-14-2012, 02:51 PM   #8
They are pre-programmed. I just ordered a SCT 4 Bank eliminator chip so hopefully I didn't screw up when I should've went handheld all good reviews though on the SCT brand and also diablo so it's really personal preference really.
Old 04-14-2012, 02:52 PM   #9
Local speed shop uses SCT and he writes his own tunes
Old 04-14-2012, 05:44 PM   #10
Brad.krieg's Avatar
Send a message via Yahoo to Brad.krieg Send a message via Skype™ to Brad.krieg
The 95 svt was only rated 240hp at the crank from the factory, so those are actually really good numbers.
Those pushrod motors respond pretty well to big heafty cams. Might want to look into that...
You got yourself a collectors car there man, very nice!
Brad.krieg is offline   Reply With Quote
Old 04-14-2012, 05:49 PM   #11
depending on your trans thats rought 20 hp gain
Old 04-14-2012, 06:16 PM   #12
Guess I just had high expectations for it lol thanks for the support though, makes me feel a little better
Old 04-14-2012, 06:45 PM   #13
Re: Dyno results :-(
There is around an 18% loss for cars with automatic transmissions that have lockup torque converters.
221 x 18% = 39.78 +221 = 260.78 FWHP
Old 04-14-2012, 07:03 PM   #14
NeedSomeMods's Avatar
I'm not following this math at all..
2000 V6 - RIP
The '94 -
NeedSomeMods is offline   Reply With Quote
Old 04-14-2012, 07:10 PM   #15
Why not it is simple?
You take the power produced at the rear tires, multiply it by the 18% loss or .18 to find out how much power was lost, then you add that power back onto the RWHP to get an approximation of the FWHP.
Old 04-14-2012, 07:21 PM   #16
Filibuster
What % for a standard trans?..
XXSTEVEO66 is offline   Reply With Quote
Old 04-14-2012, 07:43 PM   #17
For standards 15-16% and a regular non-lock up converter automatic is around 20%
Old 04-14-2012, 07:46 PM   #18
I believe these percentages are a nhra standard.
Old 04-14-2012, 07:50 PM   #19
Yep, and they will get you "ballpark" estimates not exact.
Old 04-14-2012, 07:53 PM   #20
Filibuster
So then roughly my car puts 189hp to the ground...
Old 04-14-2012, 08:05 PM   #21
So mines stick shift so it's around 15% loss
Old 04-14-2012, 08:44 PM   #22
Filibuster
Just curious ive never had a car dyno'd what gear do they run for the test?..
Old 04-14-2012, 08:46 PM   #23
Most YouTube videos I see they do 4th.but I have never had one either.so I am a little curious to.
Old 04-14-2012, 08:47 PM   #24
Brad.krieg's Avatar
I'm pretty sure 3rd to 4th most of the time
Old 04-14-2012, 08:50 PM   #25
Sorry, I thought yours was auto.
221 x 15% = 33.15 +221 = 254.15 FWHP
Old 04-14-2012, 08:51 PM   #26
Usually 4th gear or whatever gear provides a 1-1 ratio I believe.
Old 04-14-2012, 09:01 PM   #27
Filibuster
Ok..that makes sense..unless its an auto?..an auto would always drop to a passing gear so do they start they test at a certain mph to attain 4th?...
---------- Post added at 10:01 PM ---------- Previous post was at 09:56 PM ----------
I feel like I just,answered my own question
Old 04-14-2012, 09:21 PM   #28
Not real sure about the autos, but I would assume they place the AOD's in the last gear before OD and maybe the dyno does not exert enough drag to pull them down enough to shift into a lower gear.
I'm sure their Dyno computers have settings to accommodate the auto trans however they do it.
Old 04-14-2012, 09:28 PM   #29
this also makes ne wonder a little bit about the aem dyno shaft.does it records data all the time right?
Old 04-15-2012, 01:52 AM   #30
I assume so. It's been too long since I last looked at it to be sure.
Old 04-16-2012, 01:44 PM   #31
jhagan1980's Avatar
The only difference that I know of between our cars is I have long tube headers, TB, and adjustable fuel regulator. Why does mine pull 264hp and 366tq?
jhagan1980 is offline   Reply With Quote
Old 04-16-2012, 02:37 PM   #32
Were they done on the same dyno? I ask because synod do vary.also the longtubes should be good for a little and the th helps. But that does seem to be more than I would expect.
Old 04-16-2012, 03:15 PM   #33
jhagan1980's Avatar
Same exact Dyno
Old 04-17-2012, 05:50 AM   #34
And a tune which still wouldn't make up 100 ft pounds hope someone can shed some light on this lol
Old 04-17-2012, 09:37 AM   #35
jhagan1980's Avatar
I forgot I had a SCT chip with custom tune.
03:10 AM
