Cam id? - Mustang Evolution
Old 04-16-2012, 01:20 PM   #1
Foureyeguy's Avatar
Cam id?
I bought a car with a blown 306 in it, the guy told me he thinks it has a b303 cam in it I pulled it out the only marking I can find on it say MD 2h2 then in the last journal a Z anyone have any idea on what that would be? I'm thinking it's a stock cam
Foureyeguy is offline   Reply With Quote
Old 04-16-2012, 02:43 PM   #2
I can't come up with anything on Google. The only way I can come up with is to measure.you can measure the lobes with a depth micrometer.or put the cam on 2 small v blocks and use a dial indicator to measure lobe lift.if you have a degree wheel you can use that while on the v blocks to measure lobe separation.then compare to stock and common cams.I'm afraid this is the only way to tell for sure.but this should be easy to do as long as you have the proper measuring tools.
01:41 PM
