Vacuum hoses - Mustang Evolution
Old 04-16-2012, 08:08 PM   #1
Travis B's Avatar
Vacuum hoses
I was looking under the hood on my car tonight. What I was wondering was if I could get rid of the vacuum canister. Alot of my vacuum lines are in bad shape so I was gonna try to clean it up a little. I thought I heard that you could loose the vac canister but there is a sensor of some sort from the can to my intake. So what all lines can I get rid of or block off to make my motor look cleaner. My smog pump is unhooked.
Also there are a couple of looks like sensors on the passenger fender that goes to a large vac connector that has 4 lines on it. Can I get rid of it too? Any help would be great. I'm gonna replace the vac lines but if I can get rid of some not being used in the process that would be awesome.
Thanks in advance.
Travis B is offline   Reply With Quote
Old 04-17-2012, 04:53 AM   #2
Travis B's Avatar
I meant to say that it is called the carbon canister. I was looking through my chitons book and that is what they call it. Can I just unhooked the vent lines from it and remove it or do I need to keep it. What would I need to do with the vent line from the gas tank?
Old 04-17-2012, 05:48 AM   #3
This actually helps keep the fumes down.you should probably keep it.I did take mine off though.but I am carbed, so I wasn't worried about sensors.
Old 04-17-2012, 08:07 PM   #4
Re: Vacuum hoses
+1
The tank will still need to be vented and without it it you would have raw, easily ignitable fumes being expelled.
Old 04-17-2012, 11:29 PM   #5
etc1006's Avatar
You could always do wire/hose tucks to clean 'er up some...
etc1006 is offline   Reply With Quote
Old 04-18-2012, 03:46 AM   #6
Travis B's Avatar
Does anybody know off their head what all size vac hoses are under my hood? I'm gonna go ahead an replace all of them an that way I can just go to auto zone and get several feet of the sizes I need. Thanks.
Old 04-18-2012, 06:11 AM   #7
Re: Vacuum hoses
No, but you can just pull one end off and measure the ID of each size hose.
Here's a kit on eBay. The seller has a 100% reputation.
04:42 PM
