Instrument cluster - Mustang Evolution
Old 04-17-2012, 09:58 PM   #1
89 coupe's Avatar
Instrument cluster
I Have checked everything in my instrument panel and I can't get all the bulbs to work or there very dim. I put in a new rheostat for brightness but it didn't help. Does any one know of any restoration places doing fox instrument panels or parts. I also changed the little circuit board on the rear.
89 coupe is offline   Reply With Quote
Old 04-18-2012, 06:28 AM   #2
Re: Instrument cluster
Sounds like you have a bad ground to the board.
Did you adjust the rheostat?
Old 04-18-2012, 08:10 AM   #3
do they have a dimmer factory?
Old 04-19-2012, 05:57 AM   #4
89 coupe's Avatar
Ya I have adjusted, push, pulled and traced wires . I'll start checking grounds next.
And yes my 89 has a gauge dimmer on the lower left dash next to the steering column. Its an rheostat that dimmed the lights.
Old 04-19-2012, 06:17 AM   #5
This might take some time to figure out. It could be a bad ground, basically anywhere between the switch and all points of the cluster or a burned spot on the cluster, or even in the headlight switch itself. For that matter, your brand new rheostat may be defective.
All41 is offline   Reply With Quote
Old 04-19-2012, 05:20 PM   #6
89 coupe's Avatar
Your right man it's going to be awhile now blowed out my rotator cuff in my shoulder at work last night. Not much call for a one arm ninja right now so I'll need to heal up.
Old 04-23-2012, 03:34 AM   #7
Ouch! that's not a "fixes itself" kinda problem. Too bad. I hope ya get it fixed because I hear it's painful when you move the affected arm or at least when you strain it.
Old 04-23-2012, 04:54 AM   #8
89 coupe's Avatar
Ya I know I'm going to have to get it repaired. I'm down for awhile. It's my shifting arm. Lol
11:39 PM
