89 lx HELP - Mustang Evolution
Old 04-19-2012, 02:03 PM   #1
Doe_Rae_mi's Avatar
89 lx HELP
What size belt for an 89 lx 5.0 with under drive pulleys to bypass smog pump?
Old 04-19-2012, 02:24 PM   #2
intensive's Avatar
You can just take a piece of yarn or string and wrap all around your pullys and just measure the length where the two ends meet
intensive is offline   Reply With Quote
Old 04-19-2012, 02:30 PM   #3
Filibuster
You can do as metioned above and you can ask your local auto parts,store for belts near these sizes depending on your setup!....this pic always seems to come back around
XXSTEVEO66 is offline   Reply With Quote
Old 04-19-2012, 02:34 PM   #4
Filibuster
I have a setup close to the bottom left pic and also have underdrive pulleys and if I remender correctly im using a 72 or 72.5 belt..
Old 04-19-2012, 02:41 PM   #5
its hard for anyone to tell you exactly because all u d pulleys may not be the same. i use the string technique mentioned but instead of string i like to use the old belt. i cut it to length and then tape it back together. then when i go to the store i just compare.
Old 04-19-2012, 04:08 PM   #6
Doe_Rae_mi's Avatar
Thanks guys!!
10:36 PM
