Leaking main gasket - Mustang Evolution
Old 04-19-2012, 08:46 PM   #1
Leaking main gasket
Well I have a leak from the main gasket but it doesn't leak unless I'm really getting on it is there a reason for that?
Chevy eater1817 is offline   Reply With Quote
Old 04-19-2012, 08:48 PM   #2
you talking about head gasket? what year, make , model you have?
Old 04-19-2012, 08:52 PM   #3
89 foxbody and no it is leaking oil in to the inspection plate from in front of the fly wheel.
Old 04-19-2012, 08:56 PM   #4
ahh, rear main seal.well im not an expert at this one. but it does make sense. the oil pump is driven by your distributor. so the faster it spins the more it pumps. also your crank would be moving alot faster to.
Old 04-19-2012, 09:03 PM   #5
Well would it be easier to jack the motor out or drop the Trans to replace it?
Old 04-19-2012, 09:20 PM   #6
it would be easier to just drop the trans. if you have a manual it would be a good idea to change the clutch, pilot and tob bearing, of course unless its new. when you take the old seal out you can keep it to use when tapping the new one in so you dont damage the new one.
Old 04-19-2012, 09:41 PM   #7
Alright thanks I will do that.
Old 04-19-2012, 10:51 PM   #8
Re: Leaking main gasket
Because when you are "really getting on it" it throws all of the oil to the rear of the engine.
08:21 AM
