gt40 upper amd lower and maf upgrade! - Page 6 - Mustang Evolution
Old 05-14-2012, 01:25 PM   #176
87blackonblack's Avatar
This is very helpful thanks everyone
87blackonblack is offline   Reply With Quote
Old 05-14-2012, 03:18 PM   #177
Pete Jones
90mustangLX's Avatar
Send a message via ICQ to 90mustangLX Send a message via AIM to 90mustangLX
Originally Posted by 93slowstang
It is the driver side, got some sitting in storage waiting for my car. Had to do what Trojan is suggesting because I forgot when I went to pull them.
Kk, I thought it was passenger so thanks for the clarification
90 LX hatchback
(sold but not forgotten)
89 LX Notchback
No motor/trans (for now)
90mustangLX is offline   Reply With Quote
Old 05-14-2012, 05:02 PM   #178
Re: gt40 upper amd lower and maf upgrade!
Thank you for the confirmation.
Old 05-24-2012, 05:53 PM   #179
351 d5 heads are these any good.
Old 05-24-2012, 06:04 PM   #180
No, not really worth the effort to rework and install. D5 = 1975
Old 05-24-2012, 06:16 PM   #181
Thanks man thats what I needed they are Free I can see why now
Old 05-24-2012, 06:20 PM   #182
1. They'd be fine for a stock build if you ever needed them.
2. They are free.
Old 05-24-2012, 06:55 PM   #183
2. They are free.
Word lol
Also will a 10" wide tire fit on a 7" wide rim
Old 05-24-2012, 07:01 PM   #184
Pete Jones
Word lol
You can fit a 12.50 wide tire on a 7 inch rim but don't expect to air down very much
90 LX hatchback
89 LX Notchback
Old 05-24-2012, 07:17 PM   #185
Ok thank you! What would be a low on air pressure then like 15 lbs or less or more ? Lol
Old 05-24-2012, 07:22 PM   #186
Pete Jones
Ehhh, depends on the sidewall I guess. I've always ran close to max pressure with a 12.50 on a 7 inch wide rim. I would say no lower than 20-25 in a straight line no hard cornering, run the risk of popping off the bead and spinning outta control.
90 LX hatchback
89 LX Notchback
Old 05-25-2012, 03:59 AM   #187
Lol well my tires are ten inches wide just have top find done rims to put them on
Old 05-25-2012, 11:21 AM   #188
Don't put them on a to narrow rim. It is dangerous and it pulls the tread up at the edges and wears out the center of the tire.
This also reduces your contact patch and negates any benefits of the wider tire.
Old 05-25-2012, 01:32 PM   #189
I'm going to go a different route found a set on drag rims already with only two passes. For $150 its nice to have nice friends
Old 05-25-2012, 02:10 PM   #190
SCORE!
Old 05-25-2012, 08:16 PM   #191
Major dilemma think my clutch went out or my cable broke. My pedal got real light real fast weren't straight to the floor and won't go into gear at all.
When I try to put it into reverse it just grinds.
Any suggestions?
PS I was just driving normal cruising home with my kids.
Old 05-25-2012, 08:17 PM   #192
That definitely sounds like a cable issue.
Old 05-25-2012, 08:22 PM   #193
Any suggestions?
+1 Cable or less likely the pressure plate failed.
If you still have the factory quadrant, now would be the time to replace it with an aftermarket one and an external adjuster. For a cable I only use the factory type supplied by Maximum Motorsports, you can read why on their website.
Old 05-25-2012, 08:33 PM   #194
As far as I know its all still factory. When I bought i.was told it had a new clutch. And I have never had a problem with it until tonight. Iturned tbe corner from a dead stop I was in first went to shift pedal went to the floor and nothing.
I limped it home and shut it off goes through all the gears fine shut off and starts if I put the pedal to the floor, but if its in gear it just jumps forward and stalls. When its started it will just not go into gear at all.
Old 05-25-2012, 08:33 PM   #195
Pete Jones
You sure it didn't slide out of the fork underneath? If u have the stock quad try and adjust the slack and see if that changes anything
Also thinkin maybe the clutch is stuck to the flywheel as in the clutch material disintegrated altho you may have heard a pop or somethin if that happened.
90 LX hatchback
89 LX Notchback
Old 05-25-2012, 08:37 PM   #196
the factory quadrant is a white plastic one. like 90 said. check where the cable attaches to the fork. then check the quadrant. they have been know to fail to. if its still attached to the fork, see if you can pull on the cable. that will tell you if its broke.
Old 05-25-2012, 08:43 PM   #197
Ok I will check all this out tomorrow. My back gave out on me tonight so im layed up now. Hopefully it goes away tonight so I can get my car figured out. ( I really dont want to drove my trick this weekend its beautiful out.)
Old 05-25-2012, 08:44 PM   #198
hopefully its by the fork then. cause with back going out it will be a pita to get to the quadrant. you have to be a contorsionist to reach that thing!
Old 05-25-2012, 08:47 PM   #199
Oh great lol
I has a car fall on me last year so my back its jacked up good. Not like TH but good.
Here is the news paper article of my accident.
My younger bro saved my life !!!
Old 05-25-2012, 08:57 PM   #200
lBRAlD's Avatar
Oh great lol
Wow that is amazing
lBRAlD is offline   Reply With Quote
Old 05-25-2012, 08:59 PM   #201
wow man. i am glad your ok. im glad your vrother was there.
some people actually take the drivers seat out to get to the quadrant. but you maybe able to reach up under there and feel if its broken. it is way up under there. like almost behind the speedo. good luck man.
Old 05-25-2012, 09:18 PM   #202
Thanks man I'll keep you guys posted and i'm sure I'll nerd some guidance tomorrow ;( nite all thus young buck is out lol
Old 05-25-2012, 09:28 PM   #203
Oh great lol
Wow dude, that was something. Those younger brothers can be right handy at times, no?
I'm glad you made it through that in relatively good shape.
P.S. That's worse than my injuries in my book. At least I wasn't in danger of dying from mine like you were.
Old 05-25-2012, 09:39 PM   #204
HOLY CRAP!! Thats insane. Glad to see Ur ok
1fst86 is offline   Reply With Quote
Old 05-25-2012, 09:59 PM   #205
Yea i'm very lucky. Im 28 way to young to go. But my back comes and goes. There are days I Gerek invincible and days like today I can't move with out pain.
Hey TH maybe we can get a new sponsor for the forum " the scooter store" jk lmao
Old 05-25-2012, 10:14 PM   #206
You joke, but there are days that I could probably benefit from one of those.
Every time my wife drags me off the Wally World or some other big Mall I threaten to get into one of their "scooter carts" at which time I receive "The Look" so I never do.
P.S. At almost 53 I'm close to twice your age and believe me pain hurts worse as you age or your ability to endure it drops.
Old 05-25-2012, 10:27 PM   #207
Indeed my wife tells me ask the time I need a new line of work because i'm only making things worse. But bills have to be paid and the kids need food in their belly. SsI keeps denying me so u have no choice but to work. Pounding hammers under the table cause I don't have a medical release to go back to work. got to do what I got to do ya know)
By the way I didn't mean any disrespect just trying to make light of a crappy situation for the both of us. I pray all goes well for you my friend.
Old 05-25-2012, 10:33 PM   #208
I know what you mean. I spent years working after hours and weekends to provide my family and I with things we couldn't have otherwise afforded and yes you have to do whatever it takes to get by.
I know you meant no disrespect and I pray that all goes well for you too.
Old 06-18-2012, 01:12 PM   #209
my new Steeda adjustable clutch and cable is in and working great. love it!
but when I come to a stop and push the clutch in my car wants to stall. it fires back up any idea what this could be caused by?
Old 06-18-2012, 02:50 PM   #210
Pete Jones
Maybe the clutch is still engaging when you push the pedal causing it to stall out? Might just be a clutch adjustment.
Does it do it when you take it out of gear and come to a stop with your foot off the clutch?
90 LX hatchback
89 LX Notchback
04:44 AM
