Cam - Mustang Evolution
Old 04-25-2012, 09:56 PM   #1
Snappybadman's Avatar
Cam
I'm looking for a really nasty cam for my 302 roller motor
---------- Post added at 09:56 PM ---------- Previous post was at 09:27 PM ----------
Anyone have any ideas on a good nasty cam for a good price
Snappybadman is offline   Reply With Quote
Old 04-25-2012, 10:00 PM   #2
I like my b cam. It Lopes good. But I wouldn't consider it nasty.
Old 04-25-2012, 10:46 PM   #3
Re: Cam
CamQuest is your friend. Put in your info and let it pick the best cam for your engine.
P.S. a 'big nasty" cam isn't going to do you a bit of good unless you have the rest of the engine to back it up.
I had a big nasty cam once that was so hairy we called it the "woolly bugger" cam. I installed that bad boy with high expectations and dreams of mountainous horsepower and torque. What I ended up with was a creeping slug that barely had enough power to take off from a dead stop.
Old 04-25-2012, 11:09 PM   #4
93slowstang's Avatar
The mutha thumpr from comp cams is really choppy. I believe it doesn't sacrifice power like the cams Trojan is talking about. Might have to research them a little to find out.
Old 04-26-2012, 06:08 AM   #5
I'll have the motor to back it up now which is why lm looking for a good cam.
Old 04-26-2012, 07:54 AM   #6
Forum Car Trader
90GTNovi2000's Avatar
Why size lift can your springs in your heads support? The sky is the limit what kind of power adders will you have? Nos, turbo, supercharger... Is it a daily or a toy?
90GTNovi2000 is offline   Reply With Quote
Old 04-26-2012, 08:02 AM   #7
It's a daily/strip car gt40 heads hooker headers bbk rocker roller arms and push rods no nos or anything like that motor is at the shop getting bore to .60
Old 04-26-2012, 08:13 AM   #8
.060 is dangerous territory.
* edit*
Old 04-26-2012, 08:17 AM   #9
Forum Car Trader
Sounds like a good match for an e303 cam.. Possibly a f303 if u stiffen the springs.. What pistons are you adding?
Old 04-26-2012, 08:21 AM   #10
E303 is good but not nasty territory. I would contact a cam specialist or use the software that TH recommends. A cam expert will be able to give you the nasty idle u want with out sacrificing power. If I ever get rid of my b303 then I am gonna get a custom ground cam. They are not to much more than a shelf cam but are made to match your needs and setup.
Old 04-26-2012, 08:30 AM   #11
Forum Car Trader
Yeah but he has gt40 heads that I didn't hear of they are worked.. So unless he goes custom grind or with a smaller comp.. He needs to beef up the springs.. That's why the fms products have been a good choice for my cheaper builds.. They give a nice choppy idle "with right exhaust" very affordable and street friendly.. Especially if you ever have to pass emissions depending on car age of course..
Old 04-26-2012, 08:37 AM   #12
Agreed. Like I said I do like my b cam. I get a lot of compliments on it.
Old 04-26-2012, 08:40 AM   #13
Forum Car Trader
Same here..
Old 04-26-2012, 11:35 AM   #14
WhiteCobra94's Avatar
I like the trickFlow stage 2 cam
Here's mine idling
Old 04-26-2012, 11:57 AM   #15
Forum Car Trader
Tfs is a good route but if you match that can with the heads and intake= big power cheap...
Old 04-26-2012, 12:03 PM   #16
Quball19's Avatar
I run x-cam, aluminum heads, good power
Quball19 is offline   Reply With Quote
Old 04-26-2012, 12:05 PM   #17
Forum Car Trader
This is my b cam.. W/pypes violator's bbk shorties off road x pipe
Old 04-26-2012, 12:13 PM   #18
Ok ok here's mine
Old 04-26-2012, 01:24 PM   #19
04machazblue's Avatar
Look on the Anderson power site they have a cam that says best with gt40 heads I heard great things about them my friend has one of there cams and his car is pretty bad a**
2004 mach 1(totaled=() 93 mustang lx white
Gt40x heads,e 303 cam, Ford racing 1.6 roller rockers, cobra upper and lower intake, ram air intake, c&l bigger maf, 30lb injectors, Bbk fuel Pressure regulator, double roller timing chain,Bbk shorty headers & h-pipe,flowmasters cat back,chipped,t-5 swap king cobra clutch, 4.10 gears.
04machazblue is offline   Reply With Quote
Old 04-26-2012, 02:12 PM   #20
I'm beefing up the spring and these are the pistons I'm going with http://www.summitracing.com/parts/FMS-M-6100-M50BR/
---------- Post added at 02:09 PM ---------- Previous post was at 02:08 PM ----------
Well they are kinda like the ones I'm going with in it the guy that's doing the bore and making me a set of custom pistons for it
---------- Post added at 02:12 PM ---------- Previous post was at 02:09 PM ----------
I'm a lucky my grandfather worked for ford for over 48 yrs so he knows alot of ppl
10:58 AM
