Quad shock - Mustang Evolution
Old 04-26-2012, 10:20 AM   #1
Quball19's Avatar
Quad shock
Does it hurt to run without them?
Quball19 is offline   Reply With Quote
Old 04-26-2012, 10:36 AM   #2
Forum Car Trader
90GTNovi2000's Avatar
No I have removed several for clearance.. But if you can get the right backspaced rim if your trying for a bigger tire combo that's always best.. What is your reason to remove?
90GTNovi2000 is offline   Reply With Quote
Old 04-26-2012, 10:54 AM   #3
Re: Quad shock
they just help wheel hop issues so they can be removed, some flip them to gain a bit more room for tires
Old 04-26-2012, 11:06 AM   #4
Quball19's Avatar
Just ordered bigger tires from (mccormack racing)26/12/15. They told me would fit good but had to remove. They have taken off alot of them. ...... Just like checking with you all to double check, respect you guys input .. Tires are Mickey Thompson S/R
---------- Post added at 11:06 AM ---------- Previous post was at 11:01 AM ----------
Flip? Just taken off turn over?
Old 04-26-2012, 11:16 AM   #5
Forum Car Trader
Try flipping and see if you clear... If not you can remove them and be fine.. Except you might have a lil wheel hop during burnouts as stated ^
Old 04-26-2012, 11:24 AM   #6
Quball19's Avatar
Right on thanks
Old 04-26-2012, 11:28 AM   #7
Throw some good lower arms on there and it will fix any newly found hop.
Old 04-26-2012, 11:42 AM   #8
Quball19's Avatar
Do have bbk arms on there
Old 04-26-2012, 11:45 AM   #9
Forum Car Trader
Then u can delete them and be ok..
Old 04-26-2012, 11:52 AM   #10
Quball19's Avatar
Hell yea ,,, thanks you all
Old 04-26-2012, 11:54 AM   #11
Forum Car Trader
Now I have to go home and look at my lowers... Idk if mine are stock... I have the Saleen Racecraft suspension with quad shock and I'm running 26x11.50x15 on a 5.5" back spaced rim and have no rubbing issues
Old 04-26-2012, 12:30 PM   #12
Re: Quad shock
the only issue with flipping is the dirt can get in them and seize them up much easier. As said most just take em off.
Old 04-26-2012, 04:15 PM   #13
Forum Car Trader
Are these lowers stock or is this aftermarket?
Old 04-26-2012, 04:21 PM   #14
Forum Car Trader
Old 04-26-2012, 04:23 PM   #15
Aftermarket.
---------- Post added at 05:23 PM ---------- Previous post was at 05:22 PM ----------
So are the springs. But looks like stock sway bar.
06:46 AM
