04-28-2012, 08:48 PM
#1 | | Registered User
| 86 running rich
Running rich but runs pretty damn good. Changed o2 sensors, tps, and iac sensors also. New plugs, wires and cap and rotor. I'm stumped. Think it might be a stuck open injector? Thanks
04-28-2012, 08:52 PM
#2 | | Senior Member
| Re: 86 running rich Quote:
Originally Posted by lilrafe87 Running rich but runs pretty damn good. Changed o2 sensors, tps, and iac sensors also. New plugs, wires and cap and rotor. I'm stumped. Think it might be a stuck open injector? Thanks | Could be a stuck injector or a bad regulator that is allowing too much fuel pressure.
Also your temp sensors could be bad and have the ECU stuck in cold loop.
__________________ |
04-29-2012, 01:32 AM
#3 | | Registered User
Looks like I'm getting a new fpr tomorrow. Thanks
04-29-2012, 09:51 AM
#4 | | Registered User
| Re: 86 running rich
Keep it stock... don't bother with adjustable.
04-29-2012, 11:47 AM
#5 | | Registered User
Check for codes, might have a bad map sensor
04-29-2012, 12:43 PM
#6 | | Senior Member
Originally Posted by All41 Keep it stock... don't bother with adjustable. | Why not?
04-29-2012, 02:17 PM
#7 | | Registered User
Stock I shall get, but as far as the map sensor, it's new also. New vacuum line from the map to the upper intake.
04-29-2012, 03:09 PM
#8 | | Registered User
What are Ur mods?
04-29-2012, 04:50 PM
#9 | | Registered User
Pretty much stock a far as I can tell. I have an h pipe w no cats just 2 flowmaster muffs. Smog delete and a/c delete also. No upgrades as far as motor and tranny. Stock air cleaner. Thanks
04-29-2012, 08:08 PM
#10 | | Registered User
Originally Posted by Trojan Horse Why not?  | The stock one works just fine and prevents the owner from screwing up his/her fuel pressure. It also lasts longer. If you have forced induction, I suppose this is of no concern, but for anyone running N/A or with nitrous, stock is the safest bet.
I can't say why it works better, but I know that when I used a stock regulator, my pressure would peg my gauge at 125psi with nitrous(dry kit) on, but with an adjustable, the pressure remained where it was set and that causes problems.
04-29-2012, 08:10 PM
#11 | | Registered User
If u have a fuel pressure gauge, try to find out what pressure Ur running at before u throw parts at it. Have u pulled any codes
04-29-2012, 08:29 PM
#12 | | Senior Member
Originally Posted by All41 The stock one works just fine and prevents the owner from screwing up his/her fuel pressure. It also lasts longer. If you have forced induction, I suppose this is of no concern, but for anyone running N/A or with nitrous, stock is the safest bet.
I can't say why it works better, but I know that when I used a stock regulator, my pressure would peg my gauge at 125psi with nitrous(dry kit) on, but with an adjustable, the pressure remained where it was set and that causes problems. | I guess if you do not need the adjustment for tuning purposes the stock ones work just fine.
You must have had a faulty regulator. Mine ( Accufab) have always worked perfectly.
04-29-2012, 08:56 PM
#13 | | Registered User
Originally Posted by Trojan Horse I guess if you do not need the adjustment for tuning purposes the stock ones work just fine.
You must have had a faulty regulator. Mine ( Accufab) have always worked perfectly.  | To each his own, but if it ain't broke...
I put an adjustable on my last build, but it got a carburetor and the nitrous for that one was wet and ran from a different spot on the regulator, specifically to feed the nitrous system.
04-29-2012, 09:17 PM
#14 | | Senior Member
Originally Posted by All41 To each his own, but if it ain't broke...
I put an adjustable on my last build, but it got a carburetor and the nitrous for that one was wet and ran from a different spot on the regulator, specifically to feed the nitrous system. | but if it ain't broke...TINKER WITH IT!
04-29-2012, 09:19 PM
#15 | | Senior Member
| Quote: |
but if it ain't broke...TINKER WITH IT!  | Haha. I bet you at, at least one time probably had a modified stock that worked better than original. Lol
04-29-2012, 09:37 PM
#16 | | Senior Member
Originally Posted by dreamstang Haha. I bet you at, at least one time probably had a modified stock that worked better than original. Lol | I am forever "re-engineering" stuff.
It drives my wife crazy, but my modifications usually make whatever it is work better or more useful.
Most of my cars & trucks ran some better than their un-tweaked local counterparts.
First thing I always did on my old vehicles was to tune and tinker until they were performing as good as they could without tearing into the engines. There is a good bit to be had by optimizing timing, carb jetting, using lighter weight grease in the wheel bearings and rear axle, tire pressure and above all lighten those puppies up as much as possible.
Example; years ago I had a 69 Mustang GT Fastback & a cousin had a Rally Sport Nova. He had been beating other 69 & 70 Mustangs in the area, but my GT had a "tweaked" 351W under the hood and most of the other mods above. I put two car lengths on him and ruined his short reign. He never could figure out how I could beat him when other similar cars could not. He never even noticed that the back seat was missing. Let's just say he isn't the brightest bulb in the light fixture.
04-29-2012, 09:44 PM
#17 | | Senior Member
| Quote: |
Example; years ago I had a 69 Mustang GT Fastback & a cousin had a Rally Sport Nova. He had been beating other 69 & 70 Mustangs in the area, but my GT had a "tweaked" 351W under the hood and most of the other mods above. I put two car lengths on him and ruined his short reign. He never could figure out how I could beat him when other similar cars could not. He never even noticed that the back seat was missing. Let's just say he isn't the brightest bulb in the light fixture.  | Haha. Nice.
My wife calls me Tim the toolman. But like him sometimes my tinkers don't work out so good.lol
04-30-2012, 10:15 PM
#18 | | Registered User
I don't have a fuel pressure gauge. I have a brand new fuel pump and hanger. Also a new fuel filter. I have it timed at 10 degrees
05-01-2012, 06:07 AM
#19 | | Registered User
Checked codes read 63, tps voltage low, and 18, spark out (spout) ignition. Did switch out my original tps for my buddies he had laying around. He told me it was new, but I'll have to put the original back in then re test. 63 I hope isn't a pip sensor in the dist. Thanks
05-01-2012, 07:35 AM
#20 | | Registered User
Hey I'm jst wandering how do u know it's running rich. What's it doing ?
05-01-2012, 11:08 AM
#21 | | Registered User
I was about to ask the same thing
05-01-2012, 11:13 AM
#22 | | Senior Member
Originally Posted by lilrafe87 Checked codes read 63, tps voltage low, and 18, spark out (spout) ignition. Did switch out my original tps for my buddies he had laying around. He told me it was new, but I'll have to put the original back in then re test. 63 I hope isn't a pip sensor in the dist. Thanks | Here are some tests and checks for error code 63 - TPS Circuit Fault - starts about half way down the page.
Code 18 = Spout out or wiring fault/short circuit. Look for a missing Spout jumper plug, a short to ground or open circuit/broken wire in the Spout wiring going back to the ECU. It is also possible that you have a bad TFI module.
The Spout connector enables the distributor/ECU to advance the timing past the base setting. Without a working Spout connector, you are held to the timing you set at the distributor.
05-01-2012, 02:50 PM
#23 | | Registered User
Ok thanks, but I must have read the test wrong. Defiantly gives the 63, the other code I believe is 118. I already changed the coolant temp switch. Purchased it from advance auto. It is plastic. Might just throw my old one back in. ---------- Post added at 03:50 PM ---------- Previous post was at 03:47 PM ---------- Would these codes cause the car to run rich?
05-01-2012, 02:58 PM
#24 | | Senior Member
Originally Posted by lilrafe87 Ok thanks, but I must have read the test wrong. Defiantly gives the 63, the other code I believe is 118. I already changed the coolant temp switch. Purchased it from advance auto. It is plastic. Might just throw my old one back in. ---------- Post added at 03:50 PM ---------- Previous post was at 03:47 PM ---------- Would these codes cause the car to run rich? | The code 118 could I suppose if the ECU sensed it as a cold start/run condition.
05-01-2012, 08:04 PM
#25 | | Registered User
Got my old tps, I'll throw it on in the morning and see what happens. That doesn't work I'll have to get an ohm meter.
05-01-2012, 10:48 PM
#26 | | Registered User
Bad coolant temp reading will definitely make u run rich, it could keep u in open loop.
05-02-2012, 12:35 AM
#27 | | Registered User
Bought a new temp sensor from advance auto and it is plastic. My original one was metal. I'll put my original one back in and see if that fixes it. Thanks
05-03-2012, 12:32 PM
#28 | | Registered User
Pt my old tps on and now code 63 is gone, but I get code 18. Then the car wants to idle down low and seem like it wants to stall, but doesn't. Put the other one back on and it seems to run fine. I don't get it.
05-03-2012, 04:46 PM
#29 | | Registered User
How did all this come about?? Vehicle history plz
05-03-2012, 06:48 PM
#30 | | Senior Member
| Re: 86 running rich
Have you taken the car for a drive with the new parts or whenever it seems to be running ok?Just letting it idle and not go through a heating and cooling cycle may have some effect on what you are seeing.
05-06-2012, 12:48 PM
#31 | | Registered User
Took for a ride and it drives fine without idling funny. Think it's problem solved.
05-07-2012, 02:18 AM
#32 | | Senior Member
Originally Posted by lilrafe87 Took for a ride and it drives fine without idling funny. Think it's problem solved. |  That's good to hear.
