EDELBROCK PERFORMER heads - Mustang Evolution
Old 04-29-2012, 07:15 PM   #1
i looking at the performer heads @ CYLINDER HEADS, EDELBROCK, PERFORMER 5.0 1.90 VALVE EACH :: Cylinder Heads :: Engine & Components :: Mustang Parts & Accessories Superstore - 1800Mustang and i wanted to know if they are good heads from people they may have them. what cam are you running also.
Ponyexpressjr is offline   Reply With Quote
Old 04-29-2012, 07:36 PM   #2
93slowstang's Avatar
Can't go wrong with those heads, but you can find them cheaper than that site.
Old 04-29-2012, 07:42 PM   #3
Re: EDELBROCK PERFORMER heads
whats the price range of the other sites
Old 04-29-2012, 07:47 PM   #4
Check here. They are good heads but honestly I would look into some 2.02 valve heads. But I do know some people that like them.
http://search.americanmuscle.com/sea...=mustangtuning
After about 50 posts you can get a discount here for being a forum member
Old 04-29-2012, 07:59 PM   #5
i have looked at AM, was trying to find something alil bit cheaper. i heard that the 2.02 valves wouldnt work with stock pistons.
Old 04-29-2012, 08:01 PM   #6
I run trick flow heads with 2.02 valves with b cam and 1.72 rr and have clearance all day. But that is because they have redesigned combustion chambers .
Old 04-29-2012, 08:14 PM   #7
how much hp and tq is your car have, because my car is going to be strip/street car but mostly strip. i like the trick flow heads but thought i could find cheaper heads, but with the trick flow i was think thier stage 2 cam and not ford racing cam.
Old 04-29-2012, 08:17 PM   #8
I never dynoed mine. The tf topend kit says it will give you 360
---------- Post added at 09:17 PM ---------- Previous post was at 09:15 PM ----------
By all means the performers are good heads especially for the price. I paid 1200 for mine. But I got about 70$ off with the forum discount. But then I had to buy pushrods which made back up that 70$
Old 04-29-2012, 08:19 PM   #9
I have a set of Performer RPM heads that I have had on my car for over 10 years. So far no problems with them whatsoever.
I'm using the X303 camshaft, but you need to go to CamQuest to see what will work best with your combination.
They also come with either the 1.90 or 2.02 intake valves, you just need to be sure what will work with your engine.
Edelbrock is also making a couple of new set of heads called the E-Series & E-Street, you should contact them to see what would work best with your mods or plans.
Old 04-29-2012, 08:24 PM   #10
that $1200 was for the perfomers. if that would just get the trick flow head bc @ Trick Flow Twisted Wedge 170Cc Small Block Ford Aluminum Cylinder Heads at LRS - Free Shipping!
Old 04-29-2012, 08:34 PM   #11
No 1200 was the trickflow.
---------- Post added at 09:34 PM ---------- Previous post was at 09:30 PM ----------
Is the first link you listed only 1 head? Cause if so that price is for 1
Old 04-29-2012, 08:35 PM   #12
so the camquest is going to tell me what cam is safe to run without benting the valves.
Old 04-29-2012, 08:40 PM   #13
I think its more to tell u what lift and duration to make the best power. When u change your heads you will still have to check ptv clearance.
Old 04-29-2012, 08:42 PM   #14
ya i had to read it again bc i saw $836 and was like thats cheap for 2 heads, but the second link is the trick flow for $1119. i might go with them
Old 04-29-2012, 08:57 PM   #15
You can still get edelbrocks cheaper if you need a lower priced head to fit your budget. Check summit racing. They have a very large selection of heads.
http://m.summitracing.com/parts/edl-5023
---------- Post added at 09:57 PM ---------- Previous post was at 09:48 PM ----------
Like I said you will also need pushrods with these heads. So factor that in. But I couldn't be happier with them.
Old 04-29-2012, 09:07 PM   #16
Edelbrock 5023 - Edelbrock E-Street Cylinder Heads - SummitRacingEquipment.com
are you still using stock rockers
Old 04-29-2012, 09:10 PM   #17
1.72 rr. That with the b cam makes about .516 valve lift.
Old 04-29-2012, 09:26 PM   #18
e street right in my price range, just have to find a good cam. the comp cam is tell me thier 281hr grind is good, the compession ratio at 9.5.1 not sure what it would be with these heads
Old 04-29-2012, 09:29 PM   #19
I dont remember exactly what stock combustion chamber is but those are similar. So they won't change your compression ratio to much. Maybe only a couple 1/10 ths at most.
Old 04-30-2012, 02:33 PM   #20
89 coupe's Avatar
Those are the heads I'm running with 202's , my CC is 64cc had them milled a hair to match after the deck was trimmed. But a good head for street stuff.
89 coupe is offline   Reply With Quote
Old 04-30-2012, 02:54 PM   #21
which heads are those
Old 04-30-2012, 04:41 PM   #22
89 coupe's Avatar
Ford 289-351W Performer RPM Aluminum Cylinder Head. Designed for non-emissions 289, 302, and 351-Windsor Ford engines, these direct bolt-on heads deliver maximum performance in the 1500-6500 rpm range. For the performance street racer the Performer RPM #350-6025 has high-flow 2.02'' intake valves which require aftermarket pistons.
Old 04-30-2012, 08:40 PM   #23
what cam are you using
Old 05-01-2012, 03:24 AM   #24
89 coupe's Avatar
I'm in the middle of an overhaul but I was using a trick flow stage 1 with 1.7 rockers and now going to a custom grind from comp.
» Members Mustangs
98 GT
98RedGT
Tow rig
Jr79
Add your Mustang
04:55 AM
