Piston to valve clearance - Mustang Evolution
Old 04-30-2012, 04:44 PM   #1
Wondering if im gonna be ok with piston to valve clearance with gt40p heads 1.72 roller rockers and an e cam. Thanks for any help
Fox89Body is offline   Reply With Quote
Old 04-30-2012, 05:37 PM   #2
what year do you have? the only way to be sure if you have clearance is to check it. there is an article on the proper procedure in the sticky section. there are to many variable for someone to be able to give you a definate yes.
Old 04-30-2012, 07:00 PM   #3
I have an 89 gt
Old 04-30-2012, 07:11 PM   #4
those pistons should have reliefs in them so you maybe alright. but like i said i would check ptv clearance to be safe. i kow thats not the answer you were looking for. maybe someone on here has that setup idk. but even if someone tells you they run it still check.
---------- Post added at 08:11 PM ---------- Previous post was at 08:10 PM ----------
what parts do you have already?
Old 04-30-2012, 07:33 PM   #5
Ok i appreciate it. What do you mean by parts?
Old 04-30-2012, 07:46 PM   #6
do you already have heads cam and roller rockers?
Old 04-30-2012, 08:09 PM   #7
Yes the heads and cam are installed just need the pedestal rocker arm conversion kit.
Old 04-30-2012, 08:18 PM   #8
there is an article in the sticky to check piston to valve clearance with the heads on. see if you can do that with the stock 1.6 rocker arms if its even possible. if it is then we could do some math and find out if those rr's will work for you.
Old 04-30-2012, 08:24 PM   #9
I dont have the stock rocker arms. I bought the heads without them. I had 351w heads and for some odd reason thought everything would swap right over to the gt40p heads. Fail. You live and you learn.
Old 04-30-2012, 08:28 PM   #10
well then i guess its a crap shoot. maybe could score one real cheap at a junk yard just for the check? either that or see if the rr's you but are returnable incase you find out you dont have clearance?
---------- Post added at 09:28 PM ---------- Previous post was at 09:27 PM ----------
here is that article. this is the only way to check without pulling the head back off.
http://www.camshaftshop.com/camshaft...alve-clearance
Old 04-30-2012, 08:35 PM   #11
Thanks alot man. Very helpful. Just gotta cross my fingers
Old 04-30-2012, 08:38 PM   #12
No problem. I will cross mine to
12:23 PM
