500 hp - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 1979-1995 Mustang GT
Closed Thread
Old 04-30-2012, 07:11 PM   #1
allen1998gt's Avatar
allen1998gt is unknown around these parts
500 hp
I want a parts list of the quickest and cheapest way to 500 hp in my mustang 5.0
allen1998gt is offline
Old 04-30-2012, 07:15 PM   #2
Senior Member
dreamstang is unknown around these parts
quick and cheap isnt the best route for that goal.
your gonna need full hci, forced induction and supporting mods.
dreamstang is offline
Old 04-30-2012, 07:20 PM   #3
Ok do you have a parts list? And I've seen plenty of 5.0s pushing 500 without forced induction
Old 04-30-2012, 07:47 PM   #4
Senior Member
it is possible but that is a tall task for a 302. i dont think you have seem many honest ones. im not an expert motor builder here is what i would recommend.
347 stroker kit (machining will be required)
pistons with reliefs
main and valley support system
205 afr heads.
for the cam i would contact a cam specialist to make sure it works perfectly with your setup
255 lpr fuel pump
32 lb injectors
intake , performer rpm2, victor jr or spider
75 mm maf matched to your injector
80 mm throttle body
1.6- 1.7 roller rockers depending on cam selection.
fuel exhaust including long tube headers.
good pushrods(check with head manufacturer)
all pieces, throttlebody intake heads etc etc be port matched.
this still may not get you there but is close to as good as you could get to your goal(if possible) imo
im sure im missing some things or maybe off a little bit on selection. anyone feel free to chime in.
---------- Post added at 08:47 PM ---------- Previous post was at 08:45 PM ----------
and maybe a dyno tune to squeeze it all out of there
Old 04-30-2012, 07:51 PM   #5
Senior Member
Trojan Horse is just getting started.
Re: 500 hp
1. See the Useful Info thread.
2. 500 HP without a power adder is not going to be cheap or easy.
Trojan Horse is offline
Old 04-30-2012, 07:55 PM   #6
Senior Member
i agree.
did i get carried away? lol
Old 04-30-2012, 08:11 PM   #7
Senior Member
Re: 500 hp
Originally Posted by dreamstang View Post
i agree.
Nope, I didn't read closely, but I think you are close to what the builder in the article used.
Old 04-30-2012, 08:36 PM   #8
Is it easy to make 400 hp with a 2000 dollar budget ?
Old 04-30-2012, 08:38 PM   #9
Senior Member
Not really. Do you have any mods already?
Old 04-30-2012, 09:14 PM   #10
Senior Member
Re: 500 hp
Only by using a junkyard engine and a "Hail Mary" 200 HP shot of nitrous.
You can get close by using the Trickflow top end kit on your engine that makes around 360 HP.
P.S. My engine makes 405 at the crankshaft. The shortblock alone was $2500.
Edelbrock Performer RPM Heads (Port matched)
Ported Cobra Intake.
65MM TB, 75MM MAF & 24 lb Injectors.
X303 Camshaft, 1.6 Roller Rockers
BBK shorty Equal Length Headers
Old 04-30-2012, 09:38 PM   #11
How much was all that
Old 04-30-2012, 09:56 PM   #12
Senior Member
Re: 500 hp
A little over $5k.
Old 05-01-2012, 04:18 PM   #13
bad_little_pwny's Avatar
bad_little_pwny is unknown around these parts
A wise engine builder once told me this...when it comes to building a hot rod there are 3 options fast,cheap,and reliable..he said you can choose 2 of 3..meaning fast+cheap=not reliable,fast+reliable=not cheap,and cheap+reliable=not fast..just something to keep in mind
bad_little_pwny is offline
Old 05-01-2012, 05:13 PM   #14
Senior Member
tbonestang is unknown around these parts
A little over $5k.
I think I'm missing something ford seems a bit hard to make hp
tbonestang is offline
Old 05-01-2012, 05:45 PM   #15
Senior Member
Re: 500 hp
Meaning?
Old 05-01-2012, 05:58 PM   #16
Bane-'s Avatar
Bane- is unknown around these parts
Re: 500 hp
+1
Bane- is offline
Old 05-01-2012, 10:30 PM   #17
captain78's Avatar
captain78 is unknown around these parts
Look in sticky thread 400 hspr build stock 302 with just head swap with a carb. Afr 165 heads edlebrock intake carb 1.7 rockers.
---------- Post added at 11:30 PM ---------- Previous post was at 11:26 PM ----------
Sticky thread. Useful info. 4th and 5th are both on how to male 400 hspr. Out of a 302
captain78 is offline
Old 05-02-2012, 08:14 AM   #18
Senior Member
Meaning?
Prices seems a bit high for ford to make some not so impressive numbers . Not putting anyone down but if it gonna take 10000 to make a 500hp na 302 or 351 then there is something wrong . U can get a 357 making 650 hp na for 4600
Old 05-02-2012, 08:27 AM   #19
captain78's Avatar
Well according to the books for about $1500 you can get 400 hspr
Old 05-02-2012, 08:38 AM   #20
Senior Member
Re: 500 hp
Yes, quite often it does take more money to build a Ford.
My list and prices include several things that I could have done without though to be fair.
If I had utilized the stock bottom end and assembled it myself instead of buying forged pieces and having it assembled then the price would have fallen drastically from what it was and the engine would have made just as much power.
I have in the past seen 500 HP stroked 351W's assembled for around $2500 total, using bits and pieces from other Ford engines.
In my experience my buddies who built Chevrolet's usually made a bit more power than my Ford engines, but they would never last as long as my Fords did for me. It wasn't unusual for one or more of them to go through 2-3 engines in a years time. They were doing "engines per year" while I was doing "years per engine". The biggest issue with my Ford engines has always been and still is, the heads and to get a decent set I was always looking at 1k+ to replace them with something much better.
Anyways, I understand what you're saying.
Old 05-02-2012, 09:05 AM   #21
KATO's Avatar
KATO is unknown around these parts
Re: 500 hp
It seems to me that the person is just more about the "numbers" thing, so just get someone who knows how to Doc numbers on Dyno printouts, and have them just Doc up your car numbers on your Dyno. Problem solved and it's the cheap way.LOL.
07 GT. SCT: CUSTOM TUNED by MUSTANG SPECIALTIES. STEEDA: CARBON FIBER CAI. FRPP: 410 GEARS. MAGNAFLOW: AGGRESSIVE EXHAUST. BBK: LONG TUBE HEADERS & X PIPE. MSD: COIL PAK. CROSS DRILLED ROTORS. STAGGERED 22" WHL 22X8.5F-22X10R.
KATO is offline
Old 05-02-2012, 10:59 AM   #22
Senior Member
That's not the way but there was a guy in the latest issue of 5.0 1092 hp 96 stang dyno and that's from a dyno that the magazine did
Old 05-02-2012, 12:27 PM   #23
Is there a sticky on that same goal but on efi? I'm curious on seeing how it was done..cause I'm fighting the mental battle on fi vs na myself
Old 05-02-2012, 02:10 PM   #24
captain78's Avatar
No but give me a couple months and I'll tell you how it turns out lol
---------- Post added at 03:10 PM ---------- Previous post was at 03:09 PM ----------
Only thing is I'm goin with a radical cam and 1.6 rr. And EFI. So we will see
Old 05-02-2012, 02:21 PM   #25
Senior Member
Re: 500 hp
I'm assuming you mean EFI vs Carb?
What I have understood from comparison and test articles from several of the leading Mustang magazines is that:
For all around driveability and reliability the EFI is the way to go and it produces just slightly less all out power than a carburetor.
For an all out strip car where you need to extract every last ounce of power, the carburetor has a slight edge.
Old 05-02-2012, 02:45 PM   #26
No I have efi now..I'm just trying to figure out if I want to go forced induction or stay all motor.
Old 05-02-2012, 02:49 PM   #27
2300turboford's Avatar
2300turboford is unknown around these parts
Unless u have a termi
2300turboford is online now
Old 05-02-2012, 04:04 PM   #28
Forum Car Trader
90GTNovi2000's Avatar
90GTNovi2000 is unknown around these parts
Wow I caught the end of this one... yeah 500hp is a very tall task with only 2000 not happening unless u spray the hell out of it then u better start building the back up..... I have a built car with 15psi of boost only 425rwhp... If you hit the 400 mark that is good power for a street car
90GTNovi2000 is offline
Old 05-02-2012, 04:09 PM   #29
Re: 500 hp
agreed,but there is that feeling of getting use to it and just wanting more
Old 05-02-2012, 04:28 PM   #30
Senior Member
Re: 500 hp
In that case Forced Induction would be the way I would go.
To build much HP NA, you may need to run some serious compression and pretty radical camshafts which would reduce the driveability to much to suit me.
Old 05-02-2012, 07:05 PM   #31
I totally agree..a good example is my dads 89 fox its a 542ci engine with around 13:5.1 comp. Runs it on 116 octane with a 150 shot on it...I'll try to get some pics of it,honestly that car is my number 1 inspiration to keep working on mine
Old 05-03-2012, 04:53 AM   #32
Senior Member
Re: 500 hp
Pics would be nice. Get him to join up too maybe?
Old 05-03-2012, 05:02 PM   #33
I'll try my best lol he's nit super savvy with computers...old school
Closed Thread
07:06 AM
