Which heads - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 1979-1995 Mustang GT
Closed Thread
Old 05-01-2012, 07:28 AM   #1
Ajsjstang is unknown around these parts
Which heads
I have a 93 5.0 HO I was wondering if a pair of 351 heads will fit on my block I heard they will but I don't want to buy them and they not fit and my 5.0 is a roller motor isn't it?
Ajsjstang is offline
Old 05-01-2012, 08:11 AM   #2
Moderator
93slowstang's Avatar
93slowstang is unknown around these parts
Yes they will fit, but it's a waste. You won't gain anything from then over the e7 heads already in your car.
93slowstang is offline
Old 05-01-2012, 08:48 AM   #3
Re: Which heads
What heads should I get
Old 05-01-2012, 09:34 AM   #4
Forum Car Trader
90GTNovi2000's Avatar
90GTNovi2000 is unknown around these parts
Gt40's
---------- Post added at 10:34 AM ---------- Previous post was at 10:31 AM ----------
The gt40p's will also work of you have the right headers... What's your budget? But I'm sure the gt40's will be the best bang for the least amount spent... But If you can save and get some trick flows or edelbrocks it will be worth the wait
90GTNovi2000 is offline
Old 05-01-2012, 11:10 AM   #5
Moderator
Originally Posted by 90GTNovi2000
Gt40's
+1, but if you don't mind getting creative the gt40p heads don't require special headers, although they make things a lot simpler.
Old 05-01-2012, 02:49 PM   #6
Forum Car Trader
Ok what do you have to change to run the p's? Does it just have non Emissions? it's been forever since I've ran them but I know it's like an extra 40hp over e7's
Old 05-01-2012, 03:03 PM   #7
Senior Member
dreamstang is unknown around these parts
Because the p heads better mixture burn. They didn't need the pollution port on the back.some people drill them in. Others delete smog. I am not sure if this true on all of them
dreamstang is offline
Old 05-01-2012, 03:54 PM   #8
wc3john's Avatar
wc3john is unknown around these parts
Re: Which heads
351 heads are e7's so it is a complete waste
I chug syrup for money...
wc3john is offline
Old 05-01-2012, 04:05 PM   #9
Senior Member
with bigger combustion chambers i believe. which will actually lower the compression ratio.
Old 05-01-2012, 06:01 PM   #10
Bane-'s Avatar
Bane- is unknown around these parts
Re: Which heads
the p's do have specific headers due to the angle of the plug, atleastfor the shorties, there is no p specific longtube that I can remember.
just got with the frpp shorty p headers and call it a day an not spend countless hours trying to make something fit that wasnt designed to
Bane- is offline
Old 05-01-2012, 06:04 PM   #11
2300turboford's Avatar
2300turboford is unknown around these parts
Aussie 351c heads
2300turboford is offline
Old 05-01-2012, 06:22 PM   #12
Moderator
I am well aware of both the frpp and Mac p specific headers. Some of us are running non specific headers on our p heads with no problem. I'm using bbk headers on mine and only required one 90* plug. Doesn't take much.
Old 05-02-2012, 03:55 PM   #13
bad_little_pwny's Avatar
bad_little_pwny is unknown around these parts
Yep I'd recommend the gt40p heads as well...damn good bang for the buck.I'm using then on my 302 with non specific long tube headers myself and I'm very happy
bad_little_pwny is offline
Old 05-03-2012, 06:33 AM   #14
Re: Which heads
Will gt49p heads on an explorer fit? Every place I look that is selling them says they will
Old 05-03-2012, 06:44 AM   #15
Forum Car Trader
Yes p heads are from explorers.. Get them if they are cheap and send them to be vatted and milled if needed and cleaned up should only cost about $120
---------- Post added at 07:44 AM ---------- Previous post was at 07:42 AM ----------
If you can afford it get an angle job. If they can flow test take your intake in let them match the ports and polish them up.. That will be good power prob 50+ if you add the right combo
Old 05-03-2012, 11:20 AM   #16
Moderator
They also come on the 5.0 mountaineer.
Old 05-03-2012, 12:47 PM   #17
Re: Which heads
What year range for the explorer and mountaineer?
Old 05-03-2012, 12:53 PM   #18
kid_kash_00 is unknown around these parts
Never herd or seen gt40p heads put out 50 horses that's a bit much but who knows
kid_kash_00 is offline
Old 05-03-2012, 01:30 PM   #19
Senior Member
I can see it possible if the get bigger valves and milled.
Old 05-03-2012, 01:42 PM   #20
Forum Car Trader
And also match the ports to the intakes and have it polished. With a lil valve work.. Definitely 50hp gain with right cam combo
Old 05-03-2012, 02:49 PM   #21
Moderator
96-early 97 explorer= gt40
Late 97-01 explorer and all mountaineers =gt40p
Old 05-03-2012, 06:12 PM   #22
The guy I got my car from said he gained around 58 but there's a f cam and over sized valves..they are awesome if you back them up with some supporting mods
Old 05-03-2012, 10:34 PM   #23
I just didn't know not saying they didn't just never seen pull of explore bolt straight to stang and do good lol but I dunno u live u learn lol
Closed Thread
03:04 AM
