Can you use a Vortech V-1 S trim headunit from a fox for a SN95? - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 1979-1995 Mustang GT
Closed Thread
Old 05-01-2012, 11:15 AM   #1
1995boss's Avatar
1995boss is unknown around these parts
I've been looking around for a supercharger for a stock block that i want to stroke to a 331 for a decent amount of power.
Plan:
stock block
DSS stroker kit
Holley system max intake
AFR heads 185cc Or maybe something not as expensive
mild cam-not sure on specs
Other parts not planed out yet till i get a definite direction
Can you use a Vortech V-1 S trim head unit on a Sn95?
I'm not a complete expert on this so i have no idea what the difference would be with the 2. FYI it's a whole kit he is selling and i would only want the head unit.
1995boss is offline
Old 05-01-2012, 12:17 PM   #2
Senior Member
Trojan Horse is just getting started.
Re: Can you use a Vortech V-1 S trim headunit from a fox for a SN95?
Plan:
stock block
DSS stroker kit
When you buy that stroker kit, go ahead and get their main support system too.
The Vortech head unit should be interchangeable. I would contact Vortech and see just what the differences were and what it would cost for the proper brackets just to be sure.
Be sure to check condition and end and side play in the impeller before handing over any money if possible.
Trojan Horse is offline
Old 05-02-2012, 01:38 PM   #3
1995boss's Avatar
Oh yeah i plan to incorporate APR main 3/4" studs and the D.S.S. Main Support System. I'm just think about saving up for a Boss or Dart block, but im just getting impatient with waiting, and if im going to build a strong motor i might as well build everything else up as well, C4, rear end, drive shaft...list goes on.
Like people say power always finds the weak link.
1995boss is offline
Old 05-02-2012, 04:07 PM   #4
Forum Car Trader
90GTNovi2000's Avatar
90GTNovi2000 is unknown around these parts
You said it just don't make the mistake.. But you prob will I learned the hard way also.. I have to get burned first. Lol
90GTNovi2000 is offline
Old 05-02-2012, 07:06 PM   #5
WhiteCobra94's Avatar
WhiteCobra94 is unknown around these parts
I believe the only difference is the mounting bracket for the supercharger from fox to sn95
WhiteCobra94 is offline
Old 05-03-2012, 04:55 AM   #6
Senior Member
That and some slight differences in the intake connection. Nothing that cannot be overcome fairly easy though.
Closed Thread
01:43 AM
