05-01-2012, 01:04 PM
#1 | | Registered User
| 95 GT throttle Position Sensor
I need a TPS for my 95 GT. There were two different TPS produced for that year one of which is no longer made by ford or any other replacement part company as far as I know which is the F2SF 9b989 CA. This is also the model thats on my car. What I am wondering is if the other replacement part that is still available will function on my car properly.... Please help ASAP
__________________ |
05-01-2012, 02:54 PM
#2 | | Registered User
I'm at work so I can't tell you the exact # on the tps but your local autozone or other car store should have the correct one. Just walk in and ask them to look it up. Keep the screws off the old one as the new one does not come with them. When I get home I'll try and grab the product # for you. If your old ones have been on their awhile wd40 them or you'll strip the screws ---------- Post added at 02:54 PM ---------- Previous post was at 02:51 PM ---------- Quote: |
Originally Posted by Pearljammer311 I'm at work so I can't tell you the exact # on the tps but your local autozone or other car store should have the correct one. Just walk in and ask them to look it up. Keep the screws off the old one as the new one does not come with them. When I get home I'll try and grab the product # for you. If your old ones have been on their awhile wd40 them or you'll strip the screws | I believe the one you have should work fine it may be slightly smaller than the original made by ford
05-01-2012, 02:57 PM
#3 | | Registered User
Thank you. I have the old TPS removed and took it to Ford dealer, autozone, napa, o'reily auto and advanced auto where all three said they could not get me the part because my specific TPS is no longer made. Ford produced two different serial numbered models of the TPS and of coarse I have the difficult one ---------- Post added at 03:57 PM ---------- Previous post was at 03:56 PM ---------- Mine reads F2SF 9B989 CA
05-01-2012, 02:59 PM
#4 | | Registered User
No prob. I had to replace mine when I put a new throttle body in. Had the same deal because they didn't have a ford one. Works just the same though
05-01-2012, 03:31 PM
#5 | | Senior Member
| Re: 95 GT throttle Position Sensor
Maybe, try asking for one for the - 1994 Ford Thunderbird 3.8L, V6, Supercharged, Gas, Fuel Injected, VIN "R".From what I researched they are the same.
Link: F2SF-9B989CA, CB
05-01-2012, 04:50 PM
#6 | | Registered User
Ok I just tried putting the other TPS option for the 95 that they offer and not the car will not start ---------- Post added at 05:49 PM ---------- Previous post was at 05:18 PM ---------- I got it started after letting it crank over two times. Drove it around town and on the highway with no complaints there. Came home shut it off and fired right back up. The only complaint I have is when i first start the car tge idle jumps to about 3500 then slowly goes to idle around 700rpm. ---------- Post added at 05:50 PM ---------- Previous post was at 05:49 PM ---------- This was one of the problem that lead me to change the TPS
05-01-2012, 05:05 PM
#7 | | Pete Jones
| Quote: |
Originally Posted by NickMac Ok I just tried putting the other TPS option for the 95 that they offer and not the car will not start
This was one of the problem that lead me to change the TPS | Have you checked to see if your throttle is sticking a little or maybe the IAC valve needs a cleaning?
90 LX 5spd swap Stock 302 GT40P heads
BBK shorties and h-pipe
flowmaster 40's dumped, Jegs Big n Littles
BBK CAI, BBK SSI-R upper and lower
Professional Products 75mm TB,Electric Fan
MSD 8.5 90 degree plug wires
05-01-2012, 05:07 PM
#8 | | Registered User
I replaced that as well last week which made a huge difference
05-01-2012, 05:39 PM
#9 | | Senior Member
hey bro. in the sticky section there is a nice write up in the useful mustang information thread called hangin, surging idle. it seems to be what your having. http://www.stangnet.com/mustang-foru...cklist.698148/
05-03-2012, 07:34 PM
#10 | | Senior Member
did you get it taken care of yet? let us know how its going
05-03-2012, 07:40 PM
#11 | | Registered User
I've been stuck at work. Probably won't get back at it til Saturday night
05-03-2012, 07:47 PM
#12 | | Senior Member
thats cool. i was just curious. you out at bp right now?
05-03-2012, 08:45 PM
#13 | | Registered User
no, I am at SunCoke energy by LTV... BP is crazy
05-03-2012, 08:57 PM
#14 | | Senior Member
That's cool. Let me know when the next sign up is.
