t 5 swap - Page 2 - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 1979-1995 Mustang GT
Closed Thread
Old 05-19-2012, 04:22 PM   #36
Senior Member
dreamstang is unknown around these parts
if your one the app long click his name or avatar area then select private message when your veiwing that thread.
do you have both bell housings?
dreamstang is offline
Old 05-19-2012, 04:43 PM   #37
Redsteel's Avatar
Redsteel is unknown around these parts
Thanks. And no only the fox bell. Thats my problem. I didnt have the corect tools for the job this morning
Redsteel is offline
Old 05-19-2012, 04:45 PM   #38
Senior Member
Trojan Horse is just getting started.
Re: t 5 swap
Click on his name in one of his posts. Select "Send a Private Message".
The only thing you can cut on the input shaft is the tip that goes into the pilot bearing.
You would need to ensure that enough is left to support the end of the shaft, otherwise the transmission will fail very quickly.
Cutting it will be difficult as it is hardened steel.
IMHO, I would not recommend it.
Trojan Horse is offline
Old 05-19-2012, 04:54 PM   #39
Senior Member
i just did a little digging around and have not found anyone else that has actually cut it.
i think the only way i would cut it if i had both full setups and could get a perfect measurement. i think the "proper" way is to actually change the input shaft.
you can you use a sn95 bell housing. but this leaves you with 2 problem which may or may not matter.
. 1: it will move the trans back. this will cause the shifter to move back.
2: you will have to make sure that the drive shaft is not to long. most people say it will be ok, but it cuts it close. so it needs to be checked.
Old 05-19-2012, 06:56 PM   #40
Redsteel's Avatar
How hard would it be to swap the input shaft?
Redsteel is offline
Old 05-19-2012, 07:01 PM   #41
Senior Member
i have never personaly done it but here is where i got some info from.
http://www.stangnet.com/mustang-foru...x-body.851216/
Old 05-19-2012, 09:04 PM   #42
robert3188's Avatar
robert3188 is unknown around these parts
Hey guys. Ended up with a like new t5z and all the parts for swap for 1000$! My question is what's the deal with the 2.95 gear set and close.ratio first and second? Just lookin for a explanation.
---------- Post added at 10:04 PM ---------- Previous post was at 09:58 PM ----------
Also, I still have 3.73 gears for the rear to be put in... Is that gonna make it scream on the highway?
robert3188 is offline
Old 05-19-2012, 09:21 PM   #43
Senior Member
Re: t 5 swap
Post up the numbers off of the tag so we can see what you have for sure.
Old 05-19-2012, 09:27 PM   #44
robert3188's Avatar
1352 249. Everywhere I look it says its a motorsports t5z. With the 2.95 gear set.
Old 05-19-2012, 10:14 PM   #45
Senior Member
Re: t 5 swap
Ok That's actually a higher ratio transmission and with the .63 OD gear you will be fine on the highway.
Old 05-19-2012, 10:19 PM   #46
robert3188's Avatar
Awesome. So what is so good bout 1st n 2nd bein close?
Old 05-20-2012, 07:30 AM   #47
Forum Car Trader
90GTNovi2000's Avatar
90GTNovi2000 is unknown around these parts
My guess would be putting all that low end torque to the ground that the 5.0 makes..
90GTNovi2000 is offline
Old 05-20-2012, 08:17 AM   #48
Senior Member
Re: t 5 swap
Getting the car moving and keeping it moving. Try shifting from 1st to 3rd sometime and you'll see what I mean.
In an ideal scenario you would want each gear change to keep your RPM's in a certain range without them falling off too much, but that would lead to too many frequent gear changes for street driven cars, so the manufacturers have to compromise a bit to keep the buyers happy.
Example: Here is a ratio set I use in an online drag racing game to keep my virtual Mustang in it's power band.
1st Gear - 2.936
2nd Gear - 2.40
3rd Gear - 1.90
4th Gear - 1.60
5th Gear - 1.31
Rearend Gear - 3.08
Compare it to the actual ratio of your transmission and you will see what I mean.
Old 05-20-2012, 09:07 AM   #49
Forum Car Trader
Virtual drag race game?? Please inform me
Old 05-20-2012, 09:27 AM   #50
Senior Member
Re: t 5 swap
Extreme Velocity 3D - Link is to the left and in my signature, my username is TJH86.
The nerve damage in my neck, arm and back make it difficult for me, but sometimes I do pretty good.
I'd love to see any of you guys on there and race with you from time to time.
Closed Thread
02:15 AM
