t 5 swap - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 1979-1995 Mustang GT
Closed Thread
Old 05-01-2012, 05:30 PM   #1
robert3188's Avatar
robert3188 is unknown around these parts
t 5 swap
Lookin to swap my aod for A T5. Lookin for tips n tricks. And also do I want a world class? And how do I do the flywheel with weight n all? Any help is appreciated
robert3188 is offline
Old 05-01-2012, 05:57 PM   #2
Bane-'s Avatar
Bane- is unknown around these parts
Re: t 5 swap
stock flywheel is 50oz just bolts up
world class would be ideal, ill google around t5's had diff codes on the tagfor how much tq they were rated for. but a t5 is a t5 bound to break sooner or later, barely can handle a stock ho motor lol
Bane- is offline
Old 05-01-2012, 06:01 PM   #3
Senior Member
dreamstang is unknown around these parts
the 90-93 models are the strongest.
dreamstang is offline
Old 05-01-2012, 06:17 PM   #4
Bane-'s Avatar
Re: t 5 swap
here it is COOL CATS » Celebrating the 1983-88 Mercury Cougar » Modifying : Ford Borg-Warner T-5 Manual Transmission Data
Bane- is offline
Old 05-02-2012, 10:17 AM   #5
Redsteel's Avatar
Redsteel is unknown around these parts
This isnt completely off the wall, but would a v6 t5 from a 94-98 last behind a bone stock 5.0 long enough to teach myself to drive a stick? I want to learn before i build my car with a manual tranny.
Redsteel is offline
Old 05-02-2012, 11:22 AM   #6
Moderator
93slowstang's Avatar
93slowstang is unknown around these parts
Yes it should be plenty strong enough as long as you aren't dogging it too much.
93slowstang is offline
Old 05-02-2012, 11:44 AM   #7
Redsteel's Avatar
Thanks man that should help alot
Redsteel is offline
Old 05-02-2012, 07:13 PM   #8
vt89gtvert is unknown around these parts
Re: t 5 swap
Are the bolt patterns the same from the V6 to the 302? I know they are in trucks, just not sure about mustangs.
vt89gtvert is offline
Old 05-02-2012, 08:27 PM   #9
robert3188's Avatar
Awesome! Thanks for the help guys.
---------- Post added at 09:27 PM ---------- Previous post was at 09:20 PM ----------
Also.... Most people say I can use factory drive shaft will it work?
Old 05-02-2012, 09:41 PM   #10
Moderator
Yes.
---------- Post added at 10:41 PM ---------- Previous post was at 10:40 PM ----------
Yes they should be the same.
Old 05-03-2012, 05:00 AM   #11
robert3188's Avatar
Sweet. Can I use the a9p ecu that's in my car?several guys have said yes.
Old 05-03-2012, 05:06 AM   #12
Senior Member
Trojan Horse is just getting started.
Re: t 5 swap
Yes.
The tune in them is just a bit less aggressive than the A9L.
Trojan Horse is offline
Old 05-03-2012, 07:31 AM   #13
robert3188's Avatar
Awesome. Any other tips for me th?
Old 05-03-2012, 09:21 AM   #14
Senior Member
Re: t 5 swap
I've always had better luck and saved money doing a swap like this by finding a wrecked car with the parts you need. That way you have every nut, bolt and part you need. Sometimes that's not possible in the time frame you might have though.
Example: On a wrecked SN95 that needed a quarter panel, I found that they were $700+ from Ford and $350 from a salvage yard. I ended up buying a mustang body that had been hit in the front for $150. So you can see the possible savings you might get. Research and price what you will need first, so you will know what you can spend on a car if there is one to be found.
I would get the following parts new.
1. Clutch, Pressure Plate & Throw Out Bearing. (Have the flywheel inspected and resurfaced.)
2. Clutch Cable, Quadrant & Firewall Adjuster. (I recommend the OEM style cable from Maximum Motorsports.)
3. Change out the fluid or oil in the transmission.
Old 05-03-2012, 10:01 AM   #15
robert3188's Avatar
Ur the best. Got a 91 world class. Stoked about it. I'm gonna get the clutch kit and now I will Def check into the cable n stuff. How tough is the re wiring?
Old 05-03-2012, 10:55 AM   #16
Senior Member
Re: t 5 swap
Shouldn't be too bad.
If you could locate a transmission harness for the T5 it may just be plug in and go.
Otherwise you will have to figure out which wires do what.
A manual with the wiring diagrams will help you in tracing out the correct wiring.
Old 05-03-2012, 11:19 AM   #17
Moderator
Shouldn't have to re-wire anything as long as he keeps the a9p
Old 05-03-2012, 11:49 AM   #18
Senior Member
Re: t 5 swap
I figured he was talking about the reverse switch?
Old 05-03-2012, 12:24 PM   #19
robert3188's Avatar
I was talkin bout reverse switch. Can the same wire be used off the aod reverse switch?
Old 05-03-2012, 06:43 PM   #20
Senior Member
Re: t 5 swap
I don't know why not, it's usually just a wire in and a wire out to carry a signal.
Old 05-10-2012, 09:36 PM   #21
Redsteel's Avatar
Alright not to reopen a can of worms here but im in a bit of a predicament. My aod tranny has cracked and it needs replacing. I wanted to do a 5 speed swap so i figured this would be the perfect time. I found a suitable replacement in an sn95 v6 tranny, or so i thought. I forgot that in 94 and 95 the input shafts are longer. Is that the same for the sn95 v6 trannys? And if it is how hard is it to swap them out?
Redsteel is offline
Old 05-10-2012, 10:20 PM   #22
Moderator
Yes they are longer by about 5/8 an inch. I don't believe you would have a problem fitting it over a fox t-5.
Old 05-11-2012, 08:10 AM   #23
Redsteel's Avatar
Would swapping bellhousings help or is it good to go the way it is?
Redsteel is offline
Old 05-11-2012, 10:18 AM   #24
Senior Member
Swap or I believe svtlx trimmed the input shaft
Old 05-11-2012, 10:22 AM   #25
Redsteel's Avatar
Ok because i have a foxbody bell housing. I got real worried there for a while
Redsteel is offline
Old 05-11-2012, 11:40 AM   #26
Moderator
No he didnt trim anything, just swapped everything. But he went from the fox to an sn95 too.
Old 05-11-2012, 12:26 PM   #27
Senior Member
I think he may have on one of his older builds then. I know he has done many builds.
Old 05-11-2012, 01:03 PM   #28
Redsteel's Avatar
Ok so to clarify i can use a fox bellhousing on the sn95 and it will fit? Or i need the sn95 bell? Ive been seein both ways said on the internet
Redsteel is offline
Old 05-11-2012, 02:26 PM   #29
Moderator
You need to use an sn95 bell housing with the sn95 trans. The input shaft is too long to use the fox bell housing.
Old 05-11-2012, 02:45 PM   #30
Redsteel's Avatar
Ok thank you very much and sorry for all thequestions
Redsteel is offline
Old 05-11-2012, 08:28 PM   #31
Moderator
It's no problem at all. Better to ask and make sure than to mess something up by not asking.
Old 05-11-2012, 09:10 PM   #32
Iluvmy5.0's Avatar
Iluvmy5.0 is unknown around these parts
Questions are what the forum is all about. We all have mustangs and different degrees of knowledge. Don't feel bad or feel like you have to apologize.
Iluvmy5.0 is offline
Old 05-19-2012, 12:27 PM   #33
Redsteel's Avatar
Ok so i got to my junkyard today and went to pull my sn95 t5 transmission. However i forgot the extensions and swivels to get the bellhousing. I hadnt anticipated having to deal with that as i was going to get the tranny out of a car with no motor. Someone said svtlx might have cut down his input shaft? I tried looking that up and couldnt find anything useful.
Redsteel is offline
Old 05-19-2012, 12:37 PM   #34
Senior Member
I said that. And I can't be sure of which thread it was. Try pm,ing him. He knows a lot about those swaps.
---------- Post added at 01:37 PM ---------- Previous post was at 01:34 PM ----------
I was able to locate the thread. I'm not sure if this helps or not, but here it is.
pics of my 96 efi conversion
Old 05-19-2012, 04:18 PM   #35
Redsteel's Avatar
It assured me that its possible but i need to pm him for the details. How do i do that?
Redsteel is offline
Closed Thread
10:51 AM
