Originally Posted by 93slowstang Only problem with that is if he gets wider wheels, the backspacing is going to change. |
Well he said, "Specific to the specifications to my 93 cobra."
I found this - "You can change the front rotors and rear axles in order to take advantange of the regular offset wheels for the 87-93 Mustang."
And these
1993 Cobra Wheel Specs:
Goodyear Eagle P245/45ZR17 tires were mounted on 17x7.5 inch aluminum wheels.
RH: F3ZZ-1007-A
LH: F3ZZ-1007-B
Offset = 1.61" or 40.9mm
Backspace = 5.36"
Bolt Pattern = 4 X 4.25"
