Opinion time !! - Mustang Evolution
Old 05-03-2012, 02:11 PM   #1
89 coupe's Avatar
Opinion time !!
What does everyone think would be a good cam with 1.7 rockers for a 331 stroker with flat top pistons with valve cuts. Elderbrock performer intake, elderbrock performer heads, 5 speed, 3.73 gear, 70 mm TB with 24 lbs injectors. And maybe next year 150 shot. It's a weekend car only for street cruising and play but if I need it it's here. I don't care about sound just performance. Thanks for any thoughts.
89 coupe is offline   Reply With Quote
Old 05-03-2012, 02:41 PM   #2
Las0mbra's Avatar
I'd call a good cam shop. They should be able to hook you up with a good custom grind cam.
Old 05-03-2012, 02:47 PM   #3
Forum Car Trader
90GTNovi2000's Avatar
+1
90GTNovi2000 is offline   Reply With Quote
Old 05-03-2012, 02:57 PM   #4
+2
Old 05-03-2012, 03:30 PM   #5
89 coupe's Avatar
I would but all the big name shops have a 4 to 5 month waiting list. You can't even call Ed Harris's shop e-mail only. That's why I was looking at a OTS cam.
Old 05-03-2012, 03:36 PM   #6
Forum Car Trader
Hmm in that case.. I had a comp mutha thumper in my old 93. I had the same heads with KB 10:1 pistons edelbrock air gap performer with a 650 Holley I can't remember the specs it's been so long I will try to find my old cam card.. The cam had a nice choppy idle.. And a nice powerband.. Just an opinion.. But custom grind is always the best there is somewhere that can cut one for you ASAP I'm sure
Old 05-03-2012, 03:46 PM   #7
Even if you don't wanna wait that long they may still have a shelf cam that will match your needs.
Old 05-03-2012, 03:51 PM   #8
Forum Car Trader
Very true.. That's a common set-up in foxes
Old 05-03-2012, 04:07 PM   #9
89 coupe's Avatar
Any good shops come to mind, I'm in southern Ohio.
Old 05-03-2012, 04:14 PM   #10
I would probably check out comp cams. You may get lucky and summit racing carry one that they recommend. Because they are located in Ohio. Also Trojan has a good cam selection tool in the Sticky section called camquest.
Old 05-03-2012, 04:22 PM   #11
89white GT's Avatar
Region: Iowa
I got a 331 stroker and have a trick flow stage 2. It works great for me.
89white GT is offline   Reply With Quote
Old 05-03-2012, 04:31 PM   #12
89 coupe's Avatar
I sent Comp Cam a fact sheet and they sent me back there recommendation. But when I checked the lift with my 1.7 rockers it was going to put me over .575 which is the max lift on my heads. So I called them back and they acted like I was bothering them. They said they would research it and email me and have not here anymore.
Old 05-03-2012, 05:10 PM   #13
Even though comp cams is pretty reputable I would give them a big FU. Try the camquest software. It will tell you the best lift and duration to use and then compare to other top brands specs.
Old 05-03-2012, 05:26 PM   #14
89 coupe's Avatar
Good thinking buddy!!! Thanks
09:38 AM
