1983 Foxbody upgrade questions - Mustang Evolution
Old 05-03-2012, 03:25 PM   #1
NateZ101's Avatar
I have a foxbody with a supercharger, cold air intake, bbm 2" exhaust. It runs at the strip a 13.00 at 1/4 and I want to get it in mid 11's. What should I do that will make it faster and street legal?
NateZ101 is offline   Reply With Quote
Old 05-03-2012, 03:30 PM   #2
Forum Car Trader
90GTNovi2000's Avatar
What heads do you have on it now? What trans and gear?
90GTNovi2000 is offline   Reply With Quote
Old 05-03-2012, 03:37 PM   #3
NateZ101's Avatar
I have the stock heads just got the car and the tranny is a 5-speed manual. I think its 3.35.
Old 05-03-2012, 03:42 PM   #4
Forum Car Trader
Well start by yanking the e7 head off.. Either find some gt40's or get a set of trick flow's or edelbrock heads. The trans should hold for now but when it goes buy a c4. A supercomp Pa with a trans brake is a great choice.. Get correct converter to match your powerband. And maybe a 373 gear..
---------- Post added at 04:42 PM ---------- Previous post was at 04:41 PM ----------
You also should stud the heads when you change them.. And you can add a lil more boost.. How much psi are you currently running?
Old 05-03-2012, 03:45 PM   #5
NateZ101's Avatar
Alright will do thanks for the help.
---------- Post added at 04:45 PM ---------- Previous post was at 04:42 PM ----------
I'm running like 9 pounds of boost
Old 05-03-2012, 03:48 PM   #6
Forum Car Trader
My car runs 11.40's in the quarter. TFS .030 pistons total seal rings.. Girdle kit on bottom end, AFR 165 heads b303 cam, 1.6 rollers gt40 upper and lower Paxton supercharger 15 psi of boost, c4 3600 stall w/loop, aluminum driveshaft, built rear end with 327 gear.. Saleen suspension.
Old 05-03-2012, 03:51 PM   #7
NateZ101's Avatar
Alright will do and yeah my friend has an 03 Kenne Bell cobra that runs high 10's. Its ridiculous.
Old 05-03-2012, 07:12 PM   #8
Re: 1983 Foxbody upgrade questions
Start with a top end kit, 3.55 or 3.73 rear end gears and finish with a good set of headers and 2.5" H or X-pipe and exhaust.
Trick Flow has a top end kit that claims 360 HP, you can find it on the American Muscle website. Contact Trick Flow before buying and ask about the compatibility of the camshaft in that package with supercharging.
foxbody
05:37 PM
