Supercharger belt shredded! - Mustang Evolution
Old 05-06-2012, 10:55 AM   #1
Forum Car Trader
90GTNovi2000's Avatar
I was just wondering what's the best route for identifying my exact length of my belt?? Here is a pic if it helps..
I know y'all are gonna say measure what you have.. Lol well that's it I got lucky to have that much.. I guess I didn't have it tight enough or was just old.. But I was hammering down and giving it Hell..
90GTNovi2000 is offline   Reply With Quote
Old 05-06-2012, 10:59 AM   #2
I always use an old belt. Cut it to length. And then tape it together at the right length. Then take it in and match it up.
Old 05-06-2012, 11:00 AM   #3
Forum Car Trader
I was thinking of some wire or rope..
Old 05-06-2012, 11:01 AM   #4
5.8GT's Avatar
It should be a 55 1/2 belt with 10 ribs.
5.8GT is offline   Reply With Quote
Old 05-06-2012, 11:02 AM   #5
Forum Car Trader
Sweet now where to get one cheap..
Old 05-06-2012, 11:03 AM   #6
A lot of people use string. But I find the belt technique more accurate cause it sits on the pulleys like it should.
Old 05-06-2012, 11:04 AM   #7
5.8GT's Avatar
32.99 at oreilly
Old 05-06-2012, 11:13 AM   #8
Forum Car Trader
Thanks 5.8.... I will go see if my local store has one.
Load some pics up I would like to see your car the engine bay is nice!!
Old 05-06-2012, 11:27 AM   #9
5.8GT's Avatar
The good news is it at the paint shop now!
Old 05-06-2012, 11:54 AM   #10
re: Supercharger belt shredded!
I'd be concerned about why, but if it was old and loose then it may have been slipping badly and just overheated?
Cheaper by almost half at Ryder Fleet Products
Old 05-06-2012, 01:30 PM   #11
Forum Car Trader
How can I tell when the belt is at the correct tension?
Old 05-07-2012, 02:27 AM   #12
They measure the force it takes to deflect the belt a predetermined amount to set the correct tension. You may have to contact Paxton to see what those specs are.
You don't want to run the belt to tight or it will damage the SC and other accessories from too much side load.
To loose and the belt will slip and eventually shred.
If you have a spring loaded belt tensioner, there is not much you can do about the belt tension unless you remove it and fabricate your own idler pulley, belt tensioning system.
Old 05-07-2012, 05:16 AM   #13
Forum Car Trader
It's a tensioner that I loosen the pulley a lil then with a 10mm turn a bolt threaded through the back of the pulley bolt makes it move up and down to put tension on the belt.. I can add as much as I want
Old 05-07-2012, 05:35 AM   #14
Then we need to find out how much tension is needed.
Old 05-07-2012, 05:42 AM   #15
I don't know what Paxton recommends but usually the longest area about a 1/4" of deflection.
Old 05-07-2012, 06:04 AM   #16
I was unable to find any exact belt tensioning specifications, so I emailed Paxton to see what they have to say about it.
Old 05-07-2012, 06:16 AM   #17
ColeJohnson's Avatar
And that's why you da man, Trojan!
2016 Comp Orange GT (current)
Old 05-07-2012, 06:19 AM   #18
Thank you, my friend.
Since I have one too, it will be good info to have.
Old 05-07-2012, 06:24 AM   #19
Forum Car Trader
That's awesome!! I'm gonna put the new one on when I'm done polishing... Gotta love having a company vehicle. Can treat my stang like the queen it is..
Old 05-07-2012, 06:28 AM   #20
Nice !
Old 05-10-2012, 08:14 AM   #21
Ok, Paxton replied and said, "You should have a ½ inch deflection on the long side of the belt."
I emailed them back and asked them how much pressure should it take to deflect the belt that 1/2", and so far no reply back.
Old 05-10-2012, 08:23 AM   #22
Forum Car Trader
Yeah that would be nice to know..
---------- Post added at 09:23 AM ---------- Previous post was at 09:21 AM ----------
I wanna take her out tomorrow so hopefully they will reply. if not I will just use pressure with 3 fingers and check deflection..
Old 05-10-2012, 03:02 PM   #23
Forum Car Trader
So I called Paxton.. And they said, " to apply pressure with fingers on the long side of the belt." which means crawl on the ground and reach up to check then lock pulley in place when 1/2" deflection is reached.. I just got it back together and it was almost in the right spot.. I added 3/8th's tension and it is a 1/2" now!! Time for a cruise tomorrow..
Old 05-10-2012, 04:30 PM   #24
Re: Supercharger belt shredded!
Seriously?
That's the strangest way to set belt tension I have ever heard of and I'd almost bet doing it like that will leave the belt to loose.
Here is what Gates Belts says about Micro-V belt tensioning. Notice the range? Quite a bit more than pulling a 1/2" of slack in the belt then tightening it eh?
Originally Posted by Gates Belts
The Krikit II is specially designed for measuring the higher tensions which are required by Micro-V® XF belts used on passenger cars, trucks and buses. The gauge is calibrated to measure tensions ranging between 50 kg and 150 kg (100 lbs to 320 lbs). Not recommended for timing belts.
I guess you can always try the squeak test method if what they told you does not work or it lets the belt slip.
Tighten the belt by feel, then squirt it with water. Rev the engine under load (driving) and listen for belt squealing. If you hear it squealing, tighten it up a little bit.
The water simulates rain and the slipping it might cause on a belt that's ok when it is dry, but is just a bit to loose for wet weather. If your belt is adjusted so it does not slip when it is wet you should be good to go.
Old 05-10-2012, 08:24 PM   #25
Forum Car Trader
10-4.. Sounds good i will squirt it down tomorrow and listen.. I'm sure it's close..
Old 05-10-2012, 08:26 PM   #26
did you get to take it for a spin?
Old 05-11-2012, 05:24 AM   #27
Forum Car Trader
Just down the road really quick.. It actually felt like it was building boost faster.. I prob had the belt loose last time when it tore up
02:40 AM
