Vibration before shifts - Mustang Evolution
Old 05-06-2012, 12:20 PM   #1
95GTvert's Avatar
Ok I have a 95 GT automatic, when I drive it normal, right before it shifts into each gear it vibrates really bad and then smooths back to normal afterwards. BUT if I am on the throttle hard or push down harder right before it shifts it doesn't do it. Feels like it vibrates the whole car, my thought is maybe drive shaft or u joint...if anyone has ever had this issue any help is greatly appreciated, thanks!
95GTvert is offline   Reply With Quote
Old 05-06-2012, 12:23 PM   #2
Re: Vibration before shifts
Sounds like you might have some clutches that are worn out.
It may be time for a rebuild.
Old 05-06-2012, 12:30 PM   #3
95GTvert's Avatar
Ugh not what I'd wanna hear lol. Also I don't know if it has anything to do with it but when I bought the car there is a B&M ShiftPLUS installed in it, I never use it but its there. I read up a little on them and didn't hear much good about them.
Old 05-06-2012, 12:35 PM   #4
he is probably right. but it is still posible that your u joints are worn. put the car up on stands and check them out.
---------- Post added at 01:35 PM ---------- Previous post was at 01:33 PM ----------
does it happen at the same higher rpm through every gear?
Old 05-06-2012, 12:39 PM   #5
95GTvert's Avatar
Yes every shift it does it, about same rpm, it seems to be a little worse between 2nd and 3rd and 3rd to 4th.
Old 05-06-2012, 12:55 PM   #6
if it does it every gear maybe it is rpm related?
Old 05-06-2012, 03:54 PM   #7
95GTvert's Avatar
Well after driving some more today I noticed that it does it also at lower speeds, still at 35 mph or so it vibrates when shifting. On the highway it vibrates around 2300 rpm. So no matter the speed or rpm, if it shifts it vibrates right before
Old 05-07-2012, 02:11 AM   #8
The B&M Shift Plus is simply an Electronic Shift Improver.
Try using it and see if it has any effect on your issue.
You probably didn't read much good about them because people buy them and expect them to cure all the ills of a failing transmission. For what it is they work ok.
Here is a page with info and instructions - B&M Shift Plus
Old 04-04-2017, 06:09 AM   #9
Mine does the same thing but it has something to do with the exhaust. It only recently started once I installed a catless mid pipe. I was thinking it mayb occurs because of my muffler which is a muffler delete type system and is straight through. I might need a chambered muffler to control the sound better?
Superman06 is offline   Reply With Quote
04:16 PM
