86 throw out bearing bad? - Page 2 - Mustang Evolution
Old 05-25-2012, 08:49 PM   #36
lilrafe87's Avatar
TH nailed it. The clips that secure the pivot ball to the fork. Can't wait to finish this project. Weather is nice in Michigan right now. 80's- 90's. T tops off, sounds good right about now!
lilrafe87 is offline   Reply With Quote
Old 05-25-2012, 08:51 PM   #37
lilrafe87's Avatar
Tried welding it, but the metal was really thin and just melted
Old 05-25-2012, 10:03 PM   #38
Re: 86 throw out bearing bad?
Yeah, that's really thin plus it is tempered so even if you had succeeded in welding it the heat would have taken the temper out of the clip and it wouldn't hold.
Old 05-26-2012, 09:19 AM   #39
lilrafe87's Avatar
Ordered from Ebay yesterday at 6pm and just got it. That's some fast shipping
Old 05-26-2012, 09:31 AM   #40
Attachment 51906
Now get to work so you can cruise this weekend.
Old 05-26-2012, 10:58 AM   #41
lilrafe87's Avatar
As soon as the wife gets home from work I can get started. Figures, it's raining now, great
Old 05-26-2012, 03:36 PM   #42
Plastic tarp and some bricks.
Old 05-26-2012, 11:38 PM   #43
lilrafe87's Avatar
What Trans fluid should I buy?
Old 05-27-2012, 05:18 AM   #44
lilrafe87's Avatar
I read online that Dexron III/mercon atf is what the borg Warner t5 calls for. idk
Old 05-27-2012, 07:49 AM   #45
It depends on if its a WC or non WC
Old 05-27-2012, 08:21 AM   #46
lilrafe87's Avatar
What's wc?
Old 05-27-2012, 08:34 AM   #47
World class. After a certain year they went from non world class to world class. There should be some info sticky section to help identify yours.
Old 05-27-2012, 08:36 AM   #48
Filibuster
World class...if it is it takes tf if not it takes gear oil.
---------- Post added at 09:36 AM ---------- Previous post was at 09:35 AM ----------
Ok *edit*
^What Dreamstang said^
XXSTEVEO66 is offline   Reply With Quote
Old 05-27-2012, 09:49 AM   #49
lilrafe87's Avatar
Old 05-27-2012, 10:10 AM   #50
lilrafe87's Avatar
I believe it's a wc t5, it has the timken stamp on the countershaft bearing race.
Old 05-27-2012, 10:12 AM   #51
If its WC then it takes what Steve said. Just make sure you are positive. Because the wrong fluid will tear up your trans.
Old 05-27-2012, 10:19 AM   #52
lilrafe87's Avatar
I researched 5 websites total that say if I have the timken stamp on that race, it's wc.
Old 05-27-2012, 10:21 AM   #53
Cool. Looks like atf it is then.
Old 05-27-2012, 10:21 AM   #54
lilrafe87's Avatar
http://www.garage-scene.com/t5-into-...dentifying.htm
In case someone else needs to know if they have a wc t5 or not. Thanks guys.
Old 05-27-2012, 10:23 AM   #55
What I usually do is pull the numbers off the tag then Google. But that is a great technique when there is no tag to be found.
Old 05-27-2012, 11:34 AM   #56
lilrafe87's Avatar
Tag reads 13-52-065 code u
Old 05-27-2012, 11:42 AM   #57
im not sure what the code u means. but it seams as if you have a non WC out of an 84 capri. now just to be sure you did use the tag id, not the case right?
http://www.britishv8.org/Articles/Bo...T5-ID-Tags.htm
Old 05-27-2012, 12:14 PM   #58
1352-065 Ford 1984 Mustang/Capri 5.0 V8 U 2.76 2.95 1.94 1.34 1.000 .63
T5 Tag ID Numbers
It's pretty easy to tell auto trans fluid from gear oil, just see what your trans has in it.
Old 05-27-2012, 12:15 PM   #59
Identification Key to Borg-Warner T5 transmission ID Tags
Beat me to the punch.
Old 05-27-2012, 12:19 PM   #60
Filibuster
T5 Tag ID Numbers
Thats how I found out..while changing the clutch I spilled atf all over..and was like ”DAMNIT!!..hey cool I have a WC trans”
But I dont know if they offered non WC in 89 GT's did they?..
Old 05-27-2012, 12:21 PM   #61
I believe they started using them in 84-85, but don't hold me to that.
Old 05-27-2012, 01:06 PM   #62
lilrafe87's Avatar
It was Trans fluid that leaked out, for sure.
Old 05-27-2012, 01:15 PM   #63
There's your answer then.
Old 05-27-2012, 07:01 PM   #64
lilrafe87's Avatar
Thanks again
Old 05-31-2012, 04:49 PM   #65
lilrafe87's Avatar
Good to use or not?
Old 05-31-2012, 05:10 PM   #66
Attachment 52558
Good to use or not?
That should be ok, but get a few more opinions to be sure.
Old 05-31-2012, 06:19 PM   #67
lilrafe87's Avatar
Ok, thx
Old 05-31-2012, 11:58 PM   #68
93slowstang's Avatar
Good to use or not?
That's good, use it in mine and no problems yet.
Old 06-01-2012, 12:04 AM   #69
I was hoping you would chime in so we could get your opinion. THX.
Old 06-01-2012, 03:57 AM   #70
lilrafe87's Avatar
Thanks again guys, greatly appreciated. Should have her all together today. Finally have time to finish what I started. Lol
08:33 AM
