86 throw out bearing bad? - Mustang Evolution
Old 05-06-2012, 12:52 PM   #1
lilrafe87's Avatar
Was picking up my buddy and on the way home my clutch wouldn't disengage and the pedal wouldn't come back up. Thought it might be the throw out bearing. Anyone else know what's up with this? Thanks
lilrafe87 is offline   Reply With Quote
Old 05-06-2012, 01:41 PM   #2
Sounds like the clutch cable, u hear it pop?
1fst86 is offline   Reply With Quote
Old 05-06-2012, 01:59 PM   #3
could be either tob or cable. but if it was the cable you sould be able to get the pedal up. you may have to lift up on it though.
Old 05-06-2012, 03:40 PM   #4
lilrafe87's Avatar
Push the clutch in and start it, it grinds. Let off of the pedal it goes away. I think tob.
Old 05-06-2012, 03:44 PM   #5
i think so then
Old 05-06-2012, 04:38 PM   #6
lilrafe87's Avatar
I'll change it out and update y'all
Old 05-06-2012, 10:39 PM   #7
i forget what its called, but if the shaft the tob rides up is galled then you may want to change it to. also its a good idea to use a steel one if the one on there is aluminum.
Old 05-07-2012, 03:24 AM   #8
Re: 86 throw out bearing bad?
It's the front bearing retainer on the transmission, and yes, if it is aluminum replace it with a steel or cast iron model.
Old 05-20-2012, 05:04 PM   #9
lilrafe87's Avatar
Valeo a good brand clutch? My clutch looks practically new and so does my pressure plate. Tob was toasted.
Old 05-20-2012, 05:05 PM   #10
lilrafe87's Avatar
Old 05-20-2012, 05:05 PM   #11
lilrafe87's Avatar
Old 05-20-2012, 05:05 PM   #12
I think its a Ford racing clutch. But I don't remember for sure.
Old 05-20-2012, 05:07 PM   #13
lilrafe87's Avatar
Kinda low on funds so I'll just get a new tob and put her back together
Old 05-20-2012, 05:20 PM   #14
most people like to change it while there in there. but if its in good shape and you dont have the funds you should be fine.
Old 05-20-2012, 05:38 PM   #15
Use some Brake Cleaner and wash the gunk and grease off the clutch and pressure plate and you should be ok. Check your pilot bearing while you are in there too.
If that is an aluminum tube on the transmission front bearing support, you should plan to replace it with a steel or iron one when you can. The aluminum ones usually wear and cause the TOB to hang up and cause problems.
Old 05-20-2012, 05:44 PM   #16
lilrafe87's Avatar
The front retainer bearing that the tob rides on its kinda ate up, but it's steel
Old 05-20-2012, 08:02 PM   #17
Then file it down and sandpaper it as smooth as possible until you can get a new one.
Old 05-23-2012, 05:00 AM   #18
lilrafe87's Avatar
Pilot bearing looks and is in good condition. Is there a grease I can use on it before I put everything back together?
Old 05-23-2012, 05:01 AM   #19
lilrafe87's Avatar
Old 05-23-2012, 05:02 AM   #20
lilrafe87's Avatar
Old 05-23-2012, 10:13 AM   #21
It appears to be and if it is a roller bearing some lithium gun grease or wheel bearing grease will work.
Old 05-24-2012, 10:05 PM   #22
lilrafe87's Avatar
Will do, thanks for the advice
Old 05-25-2012, 11:09 AM   #23
Good luck and let us know how it turns out.
Old 05-25-2012, 05:16 PM   #24
lilrafe87's Avatar
Ok, just noticed one of the clips on the clutch fork broke off. Not for the tob, but for the pivot ball. Could I get away with that being broke? Thx
Old 05-25-2012, 06:18 PM   #25
No, you should replace that to ensure it doesn't come completely off while you are driving the car.
Old 05-25-2012, 06:52 PM   #26
lilrafe87's Avatar
Ok, ordered another one.
Old 05-25-2012, 06:53 PM   #27
lilrafe87's Avatar
Got the new bearing retainer.
Old 05-25-2012, 06:55 PM   #28
lilrafe87's Avatar
Old 05-25-2012, 07:17 PM   #29
Good choice and it appears that you have a Steeda TRI-AX shifter.
Old 05-25-2012, 07:18 PM   #30
nice. looks like your about ready to get her back in there.
Old 05-25-2012, 07:18 PM   #31
lilrafe87's Avatar
Yea, that was a surprise to me. = )
Old 05-25-2012, 07:19 PM   #32
and a great suprise that was.
Old 05-25-2012, 07:23 PM   #33
lilrafe87's Avatar
If it wasn't for the clip being broke on the fork, I would be driving it by now. Crazy how something so small ruins the holiday weekend. Its all good.
---------- Post added at 08:23 PM ---------- Previous post was at 08:21 PM ----------
I was looking for a pro 5.0 shifter, but now that I have a steeda, I'm happy. My buddy was wondering why mine shifted better than his. Now we know lol
Old 05-25-2012, 07:24 PM   #34
i know you said you ordered one. but what kind of clip was it. i dont remember. if it was like a c clip or something you may have been able to pick it up locally?
Old 05-25-2012, 08:04 PM   #35
It was the clip that holds the clutch fork in place.
04:29 PM
