spray...plugs?? - Mustang Evolution
Old 05-07-2012, 05:02 PM   #1
mystang50's Avatar
spray...plugs??
Gonna hook up my 100 shot tomorrow. Ik ill be needing colder plugs but witch ones?? Will it be ok to drive on a daily basics with the colder plugs
Old 05-07-2012, 05:53 PM   #2
Fine tip iridium about 1-2 steps colder is what they use on FI cars. I would guess that's similar. It would be a good idea to have an upgraded ignition system since the plugs are colder. At minimum at least a good coil.
Old 05-07-2012, 07:01 PM   #3
mystang50's Avatar
I have a msd coil
Old 05-09-2012, 11:00 PM   #4
mystang50's Avatar
Originally Posted by mystang50
I have a msd coil
I am putting in in tomorrow for sure...doing a switch and a WOT switch...I need some suggestions for some hiding spots, any ideas for a SN95??
and anything I will need to do to motor??timing is at stock, will I need to ****** it some more?? Don't need to blow a motor
Old 05-10-2012, 07:56 AM   #5
Re: spray...plugs??
An MSD 6AL and Timing ****** control will go a long way toward protecting your engine.
What kind of switch are you trying to hide?
Activation or system arming?
You can use a small momentary push button switch for activation and hide it on the bottom of your shifter handle depending on what shifter you have.
Old 05-10-2012, 09:59 AM   #6
mystang50's Avatar
Talking about the bottle
Old 05-10-2012, 10:26 AM   #7
Re: spray...plugs??
A bottle opening closing solenoid?
That would require a simple toggle switch, that you could hide anywhere within reach.
It would probably be best to run the power through a relay and make sure the power wiring is fused or protected with a breaker.
Old 05-10-2012, 10:57 AM   #8
I think he wants to hide the bottle.
Most people hide it in the trunk. It would be a pain for maintenance, but I saw mm & ff hide a smaller sized bottle in the door. It takes some door modifications, but is pretty sick. But I am guessing that you already have a normal size bottle anyways. During that article they also showed how to hide all the lines. They ran them through the vacuum tree I think. Good article if you can find it. I wanna say it was from 07 maybe.
Old 05-10-2012, 11:05 AM   #9
Re: spray...plugs??
I totally misunderstood that!
Yeah, in the trunk down in the spare tire well or under the back seat area if you did a seat delete.
Personally I wouldn't want one in a door JIC someone hit me in the side.
If the bottle ruptured it would be like a bomb going off.
A friend of mine from CA used to design his roll cages (so he claimed anyways) to hold the nitrous and ran the lines through the vacuum hoses like you said.
Old 05-10-2012, 12:43 PM   #10
Good point. Better use the passenger door! Lol j/k
Old 05-11-2012, 12:39 PM   #11
mystang50's Avatar
I guess ima Jus put bottle in trunk, I thought the system was a hide away sys but it ain't, so not really a point in going all out to hide the bottle, when as soon as I open hood you can see the selenoids, only thing holding me back is a fuel rail adapter and a bottle fill up and I'll get to try it and see how it goes
10:56 AM
