Steeda tri-ax shifter - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 1979-1995 Mustang GT
Closed Thread
Old 05-09-2012, 07:10 PM   #1
Iluvmy5.0's Avatar
Iluvmy5.0 is unknown around these parts
I'm going to be buying a short throw on Friday. I'm leaning towards the steeds tri-ax. What do you guys think? Good? Bad? Is there a better one? Should I not use one at all?
Iluvmy5.0 is offline
Old 05-09-2012, 07:11 PM   #2
Senior Member
dreamstang is unknown around these parts
i have a cheapo in mine. but everyone around here seem to lean towards the pro 5.0 . and yes i would definitly get one.
dreamstang is offline
Old 05-09-2012, 07:16 PM   #3
Iluvmy5.0's Avatar
Who makes the pro 5.0? Hurst? What are the benefits of the short throw? I understand that there is about a 35% reduction in throw distance but some shifters mention "never miss third again". There fore this leads me to believe that there is an added benefit in the design.
Old 05-09-2012, 07:30 PM   #4
Senior Member
They have better side springs in them and in most are adjustable. You can dial in the springs to suit your shifting need. They also have adjustable stops, so if you ram your gears hard u don't tear anything up. Then as you mentioned, a shorter throw = faster shift.
http://www.latemodelrestoration.com/...ehicle=Mustang
Old 05-09-2012, 07:35 PM   #5
Iluvmy5.0's Avatar
Thanks for the help and the link. I appreciate it.
Old 05-09-2012, 07:36 PM   #6
Senior Member
No problem!
Old 05-09-2012, 07:45 PM   #7
Bobby88Stang's Avatar
Bobby88Stang is unknown around these parts
I just put a steeda tri-axe short throw in my 88 gt and I love it. I had a hurst short throw before and the steeda is better,more precise while working threw the gears!! There's no play!!
Bobby88Stang is offline
Old 05-09-2012, 08:12 PM   #8
Iluvmy5.0's Avatar
Im in a mental debate. All of the short throws are really close in price. I have the steeda g trac stage one on my car and really love their products. The pro 5.0 looks pretty solid as well. The only one I have felt is the hurst in my buddies car.
Old 05-09-2012, 09:04 PM   #9
I'm telling you brother the steeda tri-axe is worth the price!!
Old 05-09-2012, 09:15 PM   #10
Senior Member
If you go with a top brand I'm sure you won't be disappointed
Old 05-09-2012, 09:19 PM   #11
Iluvmy5.0's Avatar
The steeda was my first choice. Im going to have to stick with it then.
Old 05-09-2012, 09:47 PM   #12
Moderator
93slowstang's Avatar
93slowstang is unknown around these parts
I'm going the MGW route. The pro5.0 has a shorter throw than the steeda, at least the one in my buddy's car does.
93slowstang is offline
Old 05-10-2012, 01:23 AM   #13
Iluvmy5.0's Avatar
The pro 5.0 short throw and knob combo looked pretty exciting. I really wish I could feel both shifters. I feel like I'm only one of very few fox body's around the Fresno area that actually loves his car. If there is anyone out there from my area with a steeda or a pro 5.0 that would let me feel the shifter please let me know
Old 05-10-2012, 08:05 AM   #14
Senior Member
Trojan Horse is just getting started.
Re: Steeda tri-ax shifter
I'm not in the area, but I have had the Pro 5.0 in my car for well over 10 years now and it has worked flawlessly. I've had such good luck with it that I won't even bother to consider any other brand if I ever need another shifter.
Trojan Horse is offline
Old 05-10-2012, 03:00 PM   #15
Nicolosi11480 is unknown around these parts
im also going the mgw route. i had steeda tri axe in my old 03 gt and it was too notchy and too noisey.i have heard nothing bad about mgw.
Nicolosi11480 is offline
Old 05-10-2012, 04:10 PM   #16
Iluvmy5.0's Avatar
I'm starting to lean towards the pro 5.0.
Old 05-10-2012, 10:49 PM   #17
poorstang is unknown around these parts
Go with the steeds tri axe had one in my 86 gt back in the day and I loved it
poorstang is offline
Old 05-11-2012, 06:08 AM   #18
Forum Car Trader
90GTNovi2000's Avatar
90GTNovi2000 is unknown around these parts
Pro 5.0 has been the only type I've tried and loved it..
90GTNovi2000 is offline
Old 05-11-2012, 06:16 AM   #19
Storm13_5.0's Avatar
Storm13_5.0 is unknown around these parts
Are the Hurts shifters good ?
---------- Post added at 06:16 AM ---------- Previous post was at 06:15 AM ----------
Hurst***
Storm13_5.0 is offline
Old 05-11-2012, 09:37 AM   #20
Senior Member
Hurst***
Yes.
Most any "name brand" shifter will be good.
It just boils down to personal preference at the end of the day.
Old 05-11-2012, 09:47 AM   #21
Thanks .. What do you use personally?
Old 05-11-2012, 09:50 AM   #22
ColeJohnson's Avatar
ColeJohnson is unknown around these parts
I've used a Steeda tri-ax in my '02 GT and absolutely love it. The only other shifter I would consider along with my Tri-ax is the MGW. Both the Steeda and MGW are impeccable quality and work flawlessly. Either way you go is better than the floppy poor excuse of a shifter the stocker is. I attached some pics. One is of my wimpy stock shifter and the second is of the Tri-ax. It's really easy to see the huge difference in quality and construction. And although it looks way bigger the throw is a ton shorter and way more precise. I haven't missed a gear in probably a year. Haha
ID:	50140   Click image for larger version
ColeJohnson is offline
Old 05-11-2012, 09:53 AM   #23
Thanks for the tips man! Lol i have some trouble hitting 5th some times .. Sucks ..and it's lose and sloppy feeling .. How is the installation ?
Old 05-11-2012, 10:03 AM   #24
My install took a while just because it hadn't been touched in 100k miles so the bolts were a little stubborn and it was a small place to work in. Since then I can get the entire shifter assembly out in about 15 mins and reinstalled in another 20mins(I go a bit slower to set the boots and gaskets correctly).
The 2-3 shift and 4-5 shift are a breeze with an aftermarket shifter like Tri-ax. It practically shifts itself.
Old 05-11-2012, 10:18 AM   #25
Senior Member
The Pro 5.0.
Old 05-11-2012, 10:26 AM   #26
Damn sounds like there is a real benefit ! You have an after market clutch?
---------- Post added at 10:26 AM ---------- Previous post was at 10:25 AM ----------
And thanks Trojan horse I'll keep the pro 5.0 in mind
Old 05-11-2012, 10:29 AM   #27
Surprisingly, at 121k miles.. My GT has the original clutch. And anoter great thing about my Tri-ax is that in neutral the springs center it directly between 3-4 gears. Three is straight up and four is straight back. Great for selecting gears in a down shift. You're always confident.
Old 05-11-2012, 10:31 AM   #28
Senior Member
Wasn't sure who you were talking to, but replied anyways since your post was right after mine.
Old 05-11-2012, 10:36 AM   #29
Dang that's pretty good . I have 90,xxx on my car and it has a ford racing clutch ,well said the guy I got it from .. As sounds great , gotta love confidence
---------- Post added at 10:36 AM ---------- Previous post was at 10:31 AM ----------
I was talkin to anyone lol.. Jus lovin all the info I gettin from you guys
Old 05-11-2012, 10:48 AM   #30
Honestly, for each brand being $150-$190, you can't really make a wrong choice. But from all I hear the Tri-ax and MGW are the top two to get. And with install being easy, you can always install a shifter, try it out for a day or two, and if unsatisfied, reinstall your stocker and return it. Although that practice isn't great as a consumer... It can give you better peace of mind. And if you buy from AM they will most definitely take care of you in any way they can. AM bends over backwards for it's customers.
Old 05-11-2012, 10:52 AM   #31
I've only herd good things about them as well! I'm likin the looks of the hurst with the white ball.. But I just wanna know the performance
Old 05-11-2012, 11:10 AM   #32
If you only like the Hurst for the white ball.. You can get the Hurst-style shifter arm and knob for attachment to the tri-ax.
Steeda Billet Pro Street Shifter Handle w/ White Knob 555-7157 - Free Shipping!
Old 05-11-2012, 11:14 AM   #33
Awhhh sweet man! Thanks lol that's the best of both worlds !! So how long is your throw?
Old 05-11-2012, 11:47 AM   #34
I've never quite measured the throw between gears, but I can safely say it's less than half of the stock throw. I'd guess the total motion from a 1-2 shift is about 4-5inches of travel, and 2-3 shift is 5-6 inches. I'm just guessing about those measurements. my car is not in this city with me so I'll have to get back to you on that one in four days when I get to work on her again.
Old 05-11-2012, 11:51 AM   #35
Heck ueh man!! Thanks for all the tips this is my first mustang an I'm 19 just wanna make sure I do it up good
Closed Thread
06:35 AM
