Bogging down - Mustang Evolution
Old 05-10-2012, 04:47 AM   #1
Storm13_5.0's Avatar
Bogging down
I have a 94 5.0 with 90,xxx it has a BBK 70 mm throttle body venom rails and injectors , Hedman short tube headers and a 2.5 inch H pipe to Series 40 flow masters ... It runs fine untill 2500 rpm then it acts like its bouncing off of a rev limiter .. Any advice ?
Storm13_5.0 is offline   Reply With Quote
Old 05-10-2012, 05:34 AM   #2
deadsp0t's Avatar
MAF, is it plugged in? Is it calibrated for your injectors?
That's unimpressive
Old 05-10-2012, 05:37 AM   #3
It's plugged in.. And not that I know of and where do you get that done at ?.. They were on the car when I got it .. The previous owner said he changed the plugs and wires then it started bogging . But I checked the timing... Ad it also has 3/16 rubber fuel lines leading to the rails ..
Old 05-10-2012, 08:00 AM   #4
Re: Bogging down
3/16" fuel lines?
That's pretty small and probably won't supply enough fuel to the engine.
Old 05-10-2012, 08:02 AM   #5
Yeh and they are a soft rubber .. I've read it's supposed to have hard metal ( factory ) or braided steel lines that won't expand.. I'm only gettin 30-33 psi at idle and 40 at WOT ...
Old 05-10-2012, 08:07 AM   #6
Re: Bogging down
Your fuel pressure should be 38-40 psi at idle with the vacuum line removed from the regulator and plugged off.
Those soft rubber lines are a fire hazard and should not be used on a fuel injection fuel system. I would replace them with the proper fuel lines ASAP.
Old 05-10-2012, 08:09 AM   #7
I'll get those changed ASAP!! So do you think the fuel lines would cause the fuel pressure to be low ..
This is my first mustang just tryna learn all I can
Old 05-10-2012, 08:17 AM   #8
Re: Bogging down
I doubt they cause it to read low at idle, but they won't allow enough fuel flow at higher RPMs.
I would suspect the regulator or fuel pump if the pressure is to low.
Old 05-10-2012, 08:22 AM   #9
So would you recommend a hi out put fuel pump? And I just read the lines should be 3/8 .. And the lack of fuel would explain the sputtering when I get on the throttle ?
Old 05-10-2012, 08:56 AM   #10
Re: Bogging down
A 190 lph pump should serve your needs.
Yes, lack of fuel will do that.
That may not be your entire issue though, it's hard to tell from here.
Old 05-10-2012, 10:23 AM   #11
Thanks so much!! Alothouhh my EGR is not properly deleted and their are screws plugging 2 vaccume lines
Old 05-10-2012, 11:06 AM   #12
Re: Bogging down
If you have vacuum leaks, that will cause you some issues too.
Old 05-10-2012, 11:12 AM   #13
There aren't any vaccume lines attached to to EGR and a throttle stop sensor .. It idles rough
Old 05-12-2012, 05:49 AM   #14
87blackonblack's Avatar
Try cleaning your maf very carefully. There is a small wire insie the maf use a qtip or something soft enough not to brake the wires and rub all the build up off.
87blackonblack is offline   Reply With Quote
Old 05-12-2012, 06:10 AM   #15
Thanks !!! What cleaner if any would you suggest ?
Old 05-12-2012, 07:19 AM   #16
I just had this issue with mine several ppl ive talked to recommend a maf cleaner from local parts store I just used a small zip tie lightly scraped the carbon build up off then used a a qtip with water to get the rest off seemed to have worked for me.
Old 05-12-2012, 07:20 AM   #17
Thanks for the tip!! I'll get on that!
Old 05-12-2012, 07:23 AM   #18
No problem!
08:53 AM
