Hp? - Mustang Evolution
Old 05-10-2012, 03:12 PM   #1
FoxBody9315's Avatar
Hp?
I'm new to the stang club....what are the specs as far as hp and tq I was told hp was 205 then I read 215 then 225 (93 lx 5.0)
FoxBody9315 is offline   Reply With Quote
Old 05-10-2012, 03:17 PM   #2
93slowstang's Avatar
For a 93 it's 205hp, earlier were rated at 225.
Old 05-10-2012, 03:22 PM   #3
That's a bummer headers intake and flow masters wouldn't make much of a difference right
Old 05-10-2012, 04:49 PM   #4
Yes they do make a good difference, forgot to mention the main reason the hp rating was lower was because of a different standard for measuring.
Old 05-12-2012, 08:37 PM   #5
Re: Hp?
Also look at the 300 ftlbs. Helps alot when getting on the throttle.
If you ever see a dyno chart on the motors in our cars, they have a very flat curve. Which means they are in the power band much longer then others. So you have that power for a longer period of time, and are therefor able to beat cars with a higher peak HP (Assuming similar weights, gears, drivers, etc.).
vt89gtvert is offline   Reply With Quote
Old 05-12-2012, 10:38 PM   #6
What do you mean by the 300ftlbs
Old 05-13-2012, 06:37 AM   #7
The Blue Dragon
GrabberBlue5.0's Avatar
Ftlbs is a measurement of the torque output of the car. You cars motor puts out 300 of the magical units... At the motor. Torque is essentially the moving capacity of an object and it's ability to keep moving under much resistance. Basically put, the more torque something's got, the harder it is to stop. And in the case of your car, the more torque means a harder launch (or just more probe to spinning tires!!)
---------- Post added at 08:37 AM ---------- Previous post was at 08:37 AM ----------
Probe=prone
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 05-13-2012, 06:46 AM   #8
Re: Hp?
Simplified:
Torque - Gets the car moving.Horsepower - Keeps it moving.
07:24 AM
