Can anyone tell me if positive rear end is the easy to go? - Mustang Evolution
Old 05-10-2012, 04:54 PM   #1
89 5.0 stang's Avatar
If so what should I run ???
---------- Post added at 02:54 PM ---------- Previous post was at 02:54 PM ----------
I mean,way to go*
89 5.0 stang is offline   Reply With Quote
Old 05-10-2012, 05:48 PM   #2
Forum Car Trader
90GTNovi2000's Avatar
I think you mean posi-trac.. Which yes I think is better than the stock limited slip.. If you do a rear gear upgrade just upgrade to a posi carrier..
90GTNovi2000 is offline   Reply With Quote
Old 05-10-2012, 06:05 PM   #3
Re: Can anyone tell me if positive rear end is the easy to go?
I mean,way to go*
If you have an 89 5.0 you should have a (limited slip) posi already.
Just rebuild it with some better clutches and a stronger S-spring for better "holding" capabilities.
For a stronger center section without clutches, I would go with a Detroit Locker center.
They rattle and clack when going around corners or backing up, but they are stronger than almost anything else out there.
I have the Auburn Pro center section in my car and while it has held up great so far, the one thing I don't like about it is that it is not rebuildable. Once the "cone" clutches are shot you pretty much have to throw it away and get a new one.
My replacement will be the Detroit Locker.
Old 05-10-2012, 06:35 PM   #4
Ya I was looking at the detroit lockers they seem reasonable price wise....thank you.
Old 05-10-2012, 08:19 PM   #5
aegischief's Avatar
I ran auburn pro units in the past. Broke 2 of them on a mildly modded 94 cobra and Nitto DRs at the track. When I say broke I mean completely shattered. After the second unit bit the dust I put in a ford F150 diff with 2 extra clutches and it was a beast and handled numerous 4500 rpm launches on a prepped track.
aegischief is offline   Reply With Quote
Old 05-10-2012, 10:16 PM   #6
Dam that sounds pretty mean
« T-5 | 89 saleen »
05:44 PM
