ram hdx clutch - Mustang Evolution
Old 05-13-2012, 04:47 AM   #1
90fox's Avatar
ram hdx clutch
I got a kit installed with a used trana via my mechanic. I replaced it, because in old one 3rd was clattering real loud. Now I hear a faint noise while driving. I don't want to describe it like a clatter more like a spinning maybe slightly crooked noise lol. Is any noise normal? Mostly paranoid put tons money into car..so hear that, and looks to be like I'm leaking or sweating I should probably say trans fluid from where driveshaft connects to trans. I started another thread other day..I noticed smelling hot trans fluid. 1st time looked under car and exhaust smoking, thought nothing of. Thinking just burning carbon or whatever off exhaust. Think it smoked before anyhow. 2nd time looked under and there was a bubble of fluid on end of driveshaft just before where connects to trans. Rubbed it..red. also saw fluid on black grommet ,i guess it is, inbetween there.
trans/driveshaft. It was black like oil. I've had hard time putting in 1st couple times and 5th doesn't seem like pushes as forward as my old. The 5th thing could also be because I'm not used to it or newbie manual driver. I think I've been babying it to much trying to break in clutch.
90fox is offline   Reply With Quote
Old 05-13-2012, 06:43 AM   #2
Re: ram hdx clutch
1. Is probably the throw out bearing. A bit of noise is normal, but loud noises usually indicate it is bad. If the transmission had the original aluminum front bearing retainer it is advisable to replace it with a steel or cast iron version to ensure proper throw out bearing operation.
2. A bit of transmission fluid/oil from the rear seal is normal. Excessive fluid/oil indicates that the seal is bad or the yoke sealing surface is damaged. The smoke may just be from fluid/oil that was flung onto the pipes by the rotating driveshaft yoke.
3. I really do not understand what you are trying to convey there, but if you are having difficulty getting it into gear that can be caused by a mis-adjusted clutch or worn synchronizers in the transmission.
Old 05-13-2012, 11:16 AM   #3
90fox's Avatar
Thank you thank you trojan. Yes the noise is very faint...throw out bearing was part if kit so guess ok there. Fluid also just a bubble and yes dripping on exhaust, so should be ok there too. Misalignment possible or I have to get used to again. Thank you think just paranoid or looking for something because so much has gone wrong or fixed. I was just extremely geeked because, thought near done w mechanicals. Or at least to function well so I can start coametics and upgrades soon.
01:06 PM
