05-14-2012, 12:38 PM
#1 | | Registered User
| heads what's the best for ur money??
Trick flow,edelbrock,gt40p everything I've heard about 40s have been negative.. I was leaning towards edelbrock...help
05-14-2012, 01:40 PM
#2 | | Forum Car Trader
What's your budget and other supporting mods? Which pistons?
__________________ |
05-14-2012, 02:57 PM
#3 | | Registered User
AFRs
05-14-2012, 03:00 PM
#4 | | Forum Car Trader
I run AFR's as well..
#5 | | Registered User
I like trick flow and afr, the gt40, gt40p, and gt40x are good however they are more of a budgeted head. I just got rid of my gt40ps they flow a lot better than stock e7s but wouldn't hang with trick flow 170s or afr 185s
__________________  having a fine car that is slow is like having a hot girlfriend that won't put out!
05-14-2012, 03:03 PM
#6 | | Senior Member
I love my trickflow. But arf tfs or edelb. will all please you.
05-14-2012, 03:09 PM
#7 | | Registered User
Trick flows are expensive but amazing results in my opinion
__________________ 1991 Mustang LX - Rebuilt 302, cobra 80mm MAF, 75mm Trickflow Throttle Body, Ported GT40 Intake manifold, half inch plenum spacer, Ported trickflow twisted wedge heads w/ trackheat valvesprings, Scorpion 1.6 Roller Rockers, stock cam (for now), 24# injectors, trickflow pushrods, shorty headers, H-pipe with 4 magnaflow high performance cats, flowmaster 40s w/ axle dumps, 4.11 gears, aluminum driveshaft, Built AOD w/ 2800 stall, 16" Cobra R replicas, 245/50ZR16 street slicks...hopefully procharger next |
05-14-2012, 03:11 PM
#8 | | Moderator
| Re: heads what's the best for ur money??
It all boils down to budget and power goals. A couple hundred for 20-30hp isnt that bad especially when you consider it cost 800-1200avg for a good set of aluminum heads.
05-14-2012, 03:14 PM
#9 | | Registered User
| Quote: |
Originally Posted by 90GTNovi2000 What's your budget and other supporting mods? Which pistons? | Well I'm building a new stang foxbody to be exact I'm just about to turn 19 and wanted something fun but cheap...but fast too lol. I think I'm might go supercharged 351c but that's a lot o doe... Prob just stay with 305 and real sleve or something.. with afrs,cold air,true duals,Detroit lockers,with 4.10 geats. And a mgr shifter short throw.. for now
05-14-2012, 05:37 PM
#10 | | Senior Member
| Re: heads what's the best for ur money?? Quote:
Originally Posted by 89 5.0 stang Trick flow,edelbrock,gt40p everything I've heard about 40s have been negative.. I was leaning towards edelbrock...help | In the Edelbrock line up, I kind of like this set up and the power it makes. Edelbrock Performer RPM XT
05-14-2012, 05:46 PM
#11 | | Registered User
In my opinion AFR's are not worth the money at all. I run a set of port and polished Windsor jr. Iron heads that flow 10x better then the afr 205's I use to have
05-14-2012, 06:11 PM
#12 | | Senior Member
Originally Posted by 89white GT In my opinion AFR's are not worth the money at all. I run a set of port and polished Windsor jr. Iron heads that flow 10x better then the afr 205's I use to have | Sorry, but I find that hard to swallow.
I'd have to see some actual flow tables to believe they were that much better if any.
A set of polished and ported AFR 205's would flow some serious numbers, plus they would remove a considerable amount of weight off the front end.
Not arguing with you or dissing your opinion, just stating my own opinion.
05-14-2012, 06:23 PM
#13 | | Registered User
| Quote: |
Not arguing with you or dissing your opinion, just stating my own opinion.  | No the AFR's were not machined in any way. What I'm trying to say is I bought a set of Windsor jr iron heads striped em and had them ported and polished and they flow better then my 205's did. And buying the heads and getting them ported and polished cost less then just buying the AFR's
05-14-2012, 06:42 PM
#14 | | Senior Member
Originally Posted by 89white GT No the AFR's were not machined in any way. What I'm trying to say is I bought a set of Windsor jr iron heads striped em and had them ported and polished and they flow better then my 205's did. And buying the heads and getting them ported and polished cost less then just buying the AFR's | Ok, I see what you mean now, but I still think you'd have been much better off keeping the AFR's and porting & polishing them.
05-14-2012, 06:49 PM
#15 | | Registered User
I spend so much on the heads and didn't want to put any more money into it. Just thought sense I dropped all this money on them they would flow better then they did.
