Trick flow heads - Mustang Evolution
Old 05-15-2012, 06:47 AM   #1
04machazblue's Avatar
Trick flow heads
Was looking at trickflow heads the track heat heads part number tfs-51400015 it said I can use them with stock pistons as long as the cam lift is under 550lift they are 190 heads and I was wondering If I should get them or the 170 tw heads
2004 mach 1(totaled=() 93 mustang lx white
Gt40x heads,e 303 cam, Ford racing 1.6 roller rockers, cobra upper and lower intake, ram air intake, c&l bigger maf, 30lb injectors, Bbk fuel Pressure regulator, double roller timing chain,Bbk shorty headers & h-pipe,flowmasters cat back,chipped,t-5 swap king cobra clutch, 4.10 gears.
04machazblue is offline   Reply With Quote
Old 05-15-2012, 07:26 AM   #2
I got the 170's and wish I would of gone with the 190's but it depends on your setup!
SlyFox512 is offline   Reply With Quote
Old 05-15-2012, 07:39 AM   #3
I am using a stock 302 block gonna use a Anderson n41 cam cobra intake 30# injectors I have bin told its not to much head and then hopefully be putting it on a 351 block
Old 05-15-2012, 07:41 AM   #4
Re: Trick flow heads
If you are planning a 351W, then go for the bigger, better flowing heads.
Old 05-15-2012, 07:57 AM   #5
I think I would gain more over my current heads anyway I get beat at the track by my friends track heat headed car with a cobra intake all day he goes 12.00 flat with those heads and a cobra intake stock injectors and 430's
---------- Post added at 09:57 AM ---------- Previous post was at 09:57 AM ----------
With a stock 302 block
Old 05-15-2012, 08:01 AM   #6
I don't know what the matching head would be in Trick Flow, but in AFR I would choose the 185 or 205 head for a mild 351W and the 225 for a wilder 351W.
Old 05-15-2012, 08:21 AM   #7
I am not a big fan of Afr I have seen a lot of fast trick flow headed cars and the trick
Flows are less costly so getting back to the track heats what do u think on a stock 302 block
Old 05-15-2012, 09:23 AM   #8
Ok, I just used them as an example because I am more familiar with them.
For a stock 302, I would go with the smaller flowing heads so you do not end up with stagnant air flow in the system, BUT if you are planning a 351W build I also wouldn't want to buy heads twice, so I would go ahead and get the larger, better flowing heads and just put up with any flow issues until I got the 351W finished and could swap them over to it.
Old 05-15-2012, 06:39 PM   #9
I have the 170s. And I am happy with them. Trickflow says they flow enough to run a 351 but as suggested they wouldn't be as good as the bigger. On a stock 302 I would go with 170s If its gonna be a while before the 351.you could go with the 170s for now and get them ported. Trickflow says they have plenty of room to be ported. They also say the 170s flow as much as after 185s because the shorter runners.
Old 05-16-2012, 10:06 AM   #10
What about the 185s
Old 05-16-2012, 10:15 AM   #11
Forum Car Trader
90GTNovi2000's Avatar
185's are a good choice if you plan on building the 351..
90GTNovi2000 is offline   Reply With Quote
Old 05-16-2012, 04:44 PM   #12
I fell like the 185 are decent for a 302 it won't be to much
04:28 AM
