Wire boots vs header - Mustang Evolution
Old 05-15-2012, 10:19 AM   #1
Storm13_5.0's Avatar
I got the accel 8mm wires and the boots touch my headers will they melt ?
Storm13_5.0 is offline   Reply With Quote
Old 05-15-2012, 10:32 AM   #2
Re: Wire boots vs header
Yes, eventually they will.
They make fiberglass sleeves to help protect the boots and wires, but you still need to figure out how to keep them from directly contacting the headers.
Old 05-15-2012, 10:33 AM   #3
Dang .... You have any suggestions ?
Old 05-15-2012, 10:39 AM   #4
Yes, use the sleeves over the boots and plastic wire ties to keep them from touching.
Old 05-15-2012, 10:40 AM   #5
What if I were to wrap them in heat wrap?
---------- Post added at 09:40 AM ---------- Previous post was at 09:39 AM ----------
That's a neat set up ! I ll have to do that!
Old 05-15-2012, 10:41 AM   #6
You could, but the fiberglass plug wire sleeves are much neater and made to fit better.
Old 05-15-2012, 10:43 AM   #7
Where do you get them at ?
Old 05-15-2012, 10:46 AM   #8
Click the link in my post above or try American Muscle, Jegs, etc., etc..
Old 05-15-2012, 10:48 AM   #9
Thank you!
Old 05-15-2012, 10:51 AM   #10
Thank you!
You are welcome.
A few pictures of your wires and we might be able to offer some suggestions for tying them up.
Old 05-15-2012, 11:03 AM   #11
This is what's goin on
Old 05-15-2012, 11:13 AM   #12
Attachment 50577
Use a 90° or adjustable end on that wire.
You can get them at Summit or Jegs.
Just cut that one off and crimp on the new one.
Old 05-15-2012, 11:18 AM   #13
Do I just cut the old boot off , and use the now one ?
Old 05-15-2012, 11:23 AM   #14
Forum Car Trader
90GTNovi2000's Avatar
Yep it's not hard search it on YouTube
90GTNovi2000 is offline   Reply With Quote
Old 05-15-2012, 11:38 AM   #15
Sweet thanks !!
Old 05-15-2012, 04:48 PM   #16
What you will cut off will be just the connector inside the boot.
Spray the wire inside and just above the boot with some silicone spray.
Slide the boot up on the wire far enough to allow you to be able to work on the wire.
Cut off the wire right at the connector.
Approximately 1/2" to 5/8" up on the wire carefully cut and remove the outer and inner insulation. Try to not nick the center wire.
Once the insulation layers are removed and you are left with just the center wire, fold it back over the outside of the insulation.
Slide your new end connector on, then crimp it into place.
Spray the wire and inside the boot with a bit more silicone spray, then slide it back down to cover the connector and you are done.
Old 05-15-2012, 06:23 PM   #17
I picked mine up from summit racing for 30-40 dollars. I don't remember exatly. And I got these wire seperators from AutoZone for 5$
Old 05-15-2012, 06:25 PM   #18
What he said. But make sure you use a good set of wire crimpers.
Old 05-16-2012, 09:50 AM   #19
bigcolt45's Avatar
Trojan
I must say the zip tie wire separators look fancy! I know what I'm doing today
bigcolt45 is offline   Reply With Quote
Old 05-16-2012, 10:12 AM   #20
It's not me, it's you.
primer2tone's Avatar
Originally Posted by bigcolt45
Trojan
Makes me wish I had spark plug wires so I could do it too! Lol
Old 05-16-2012, 03:16 PM   #21
You could always get some fake ones. That would really mess with people.
Old 05-16-2012, 10:19 PM   #22
Thanks for all the help guys ! I got boots from autozone ... And I used pliers to crimp
Old 05-17-2012, 05:22 PM   #23
Originally Posted by bigcolt45 View Post
Trojan
That's an old trick I learned literally "years" ago. Works great and the ties are plastic so they won't contribute to the plug wires grounding out.
I was thinking the exact same thing, then I scrolled down and read your post.
A dedicated plug wire crimper would have been better, but pliers work in a pinch.
If you ever get a miss, check that wire first.
Old 05-19-2012, 01:50 AM   #24
A crumper came with the boot kit but idk how to use it
Old 05-19-2012, 06:57 AM   #25
You should be able to find a youtube video of it being done.
Old 05-19-2012, 08:35 AM   #26
If it is like many I have seen, you clamp one piece in a vise, position your wire and connector, then slide the other piece in place and tap it with a small hammer.
Old 05-27-2012, 07:21 PM   #27
They came in the mail install them and they work great
07:28 AM
