Gears - Mustang Evolution
Old 05-16-2012, 12:07 AM   #1
FoxBody9315's Avatar
Gears
Ok I been thinking a lot and decided to stick with my motor (302) and just building it from there.....it's 93 lx 5.0 it has intake headers and exhaust well pipes I'm assuming this is how I bought the car.....I'm going to get catted h pipes loud mouth pipes.... I was looking at 3.73 gears is that a good start with gears I'm looking to obviously gain more torque I want to launch off the line and har that **** glue you to yor seat lol.....any advice, opinions anything would be greatly appreciated....
FoxBody9315 is offline   Reply With Quote
Old 05-16-2012, 12:41 AM   #2
Re: Gears
Trick Flow Top End Kit = approx 360 Hp & 350 TQ
Old 05-16-2012, 05:57 AM   #3
I like my 3.73s
Old 05-16-2012, 06:21 AM   #4
Forum Car Trader
90GTNovi2000's Avatar
What trans is backing your 5.0? If its an AOD you can go with a 4.10 gear and still daily drive it with food gas mileage. It it's a 5 speed 373 all the way. Why are you gonna get the catted x or H pipe? You can go with an O/R setup and that will free up a lil more HP. Try putting the power you have now to the ground it may surprise you. Add the gear and maybe some Drag radials or new suspension. That will set you in your seat with a good launch. And when you want to tear the top end off definitely save for a good combo like the Trickflow setup TH recommended.
90GTNovi2000 is offline   Reply With Quote
Old 05-16-2012, 09:16 AM   #5
When I bought the car the guy said it has 4:10 in it now and yea it's a 5speed and the catted h pipe was just going off by what a co-worker told me what's o/r set up
Old 05-16-2012, 09:25 AM   #6
Forum Car Trader
The off road h or x pipe it is a non catted mid pipe which means it won't restrict airflow as much.. But some states are very tight on there emissions. so unless your car is almost 25 yrs old or you know a lick and stick inspection place. You should go with the catted one. I have always personally gone with an O/R setup.
---------- Post added at 10:25 AM ---------- Previous post was at 10:23 AM ----------
Also if it has 4.10's and it's a 5spd you will know it.. I think you will be around 2700rpms at 65mph.. But I'm not sure about that.. If you have the gear try to get some good tires on the back to add traction.
Old 05-16-2012, 09:26 AM   #7
I was thinking about that I'm in jersey my inspection good till the end of the year which is when I'll stop driving it to fix it up....so I'll go with the non cat for now and just put back the cats web going for inspection
Old 05-16-2012, 09:30 AM   #8
Forum Car Trader
Not a bad idea it wouldn't take too long to do that either.. I don't think it will affect your ECU at all.
Old 05-16-2012, 09:33 AM   #9
Now as far as the gears I'm going to go with the 3:73....I think I might need to replace clutch too the guy didn't answer my question when I asked if t was changed any recommendations there
Old 05-16-2012, 09:38 AM   #10
Forum Car Trader
If the torque isn't enough for you right now with 4.10's dropping to 3.73 will defeat the purpose.. IMO the 373 is a great gear choice but if you want more torque and power dropping to a 373 from a 410 won't do it.
---------- Post added at 10:38 AM ---------- Previous post was at 10:36 AM ----------
I have ran several clutches I find Ram to be a pretty affordable clutch and they can take a beating.. Just get a 30% over stock you will be good. Also have the flywheel resurfaced!!
Old 05-16-2012, 10:23 AM   #11
Oh boy so many choices I'm going crazy lol I'll start out with the clutch first see how that goes
Old 05-16-2012, 10:30 AM   #12
Forum Car Trader
A new clutch and fresh flywheel make a world of difference if yours is worn out.. Also do you have a short throw?
Old 05-16-2012, 10:48 AM   #13
Never owned a mustang before to be honest with you and te stick is weird it comes out crooked....so I highly doubt it has a short shifter.... Yeah I stalled out in second the other day forgot to go back in first was at a toll law I shouldn't be stalling in second so I'm assuming it's worn
Old 05-16-2012, 10:50 AM   #14
Forum Car Trader
Lol.
Old 05-16-2012, 10:58 AM   #15
Lol.
Lol yeah fml....anyway I was looking on am what do you think about the trick flow twisted wedge cylinder heads
Old 05-16-2012, 11:09 AM   #16
Forum Car Trader
That doesn't necessarily mean your clutch is bad.. It could be out of adjustment, or driver error. If your clutch is bad when shifting gears you will grind cause your clutch isn't disengaging all the way or a synchro. Or while in a gear and your accelerating it feels like it's tugging. You will learn from experience an a lil time. I would definitely recommend a short throw shifter. They are easy to install and will allow you to jam gears much quicker.. You can also adjust them to keep from overthrowing a gear and harming your trans.
---------- Post added at 12:09 PM ---------- Previous post was at 12:05 PM ----------
There an awesome set of heads. But I would hold off on them for now if I were you. Get the Trans perfect. Then look at a H/C/I swap the trick flow setup will work great and can be installed by you if you can swing a wrench.
Old 05-16-2012, 11:44 AM   #17
I can def handle a wrench lol the other day I had the clutch down trying to go into gear and it wouldn't go in till after a few tries.... H/c I'm assuming heads cams and what not right
Old 05-16-2012, 11:54 AM   #18
Forum Car Trader
Yeah heads/cam/intake. possibly injectors if you go with the Trick Flow setup. Usually end up upgrading the TB and MAF also upload some engine pics if you can lets see what you have.
Is anyone else having trouble uploading pics to there profile by phone?
Old 05-16-2012, 12:02 PM   #19
Here ya go
ID:	50704   Click image for larger version
Old 05-16-2012, 12:12 PM   #20
Forum Car Trader
From what I see the only mods you have are aftermarket headers and CAI. You can go to a junk yard or get on Craigslist and find a GT40 upper and lower intake really cheap that will be a good starting point.
Old 05-16-2012, 12:16 PM   #21
As a pose to the trick flow for now....?
Old 05-16-2012, 12:19 PM   #22
Forum Car Trader
Trick flow would be sweet if you can budget it.. J/s if you go a different route with your build..
Old 05-16-2012, 12:27 PM   #23
Yeah I'm looking over the finances now lol trick flow might be the winner....I'm going to order a short shifter tomorrow
---------- Post added at 12:27 PM ---------- Previous post was at 12:21 PM ----------
Have to replace that Cai too looks a little nasty haha
Old 05-16-2012, 12:35 PM   #24
Forum Car Trader
Why? It can be polished
---------- Post added at 01:34 PM ---------- Previous post was at 01:33 PM ----------
Get some scotchbrite and put some elbow grade on it.. Then chase it with mothers chrome polish..
---------- Post added at 01:35 PM ---------- Previous post was at 01:34 PM ----------
Cool which short throw are you going to order? Pro 5.0 is a good choice.. Installation should only take you a few hrs..
Old 05-16-2012, 04:43 PM   #25
Wheres that one at I'm looking on am don't see much of a selection there
Old 05-16-2012, 06:39 PM   #26
Forum Car Trader
I'm not sure if AM supplies it just call them and ask.. If not summit should
Old 05-16-2012, 09:34 PM   #27
I think I might end up with this one
Old 05-17-2012, 05:20 AM   #28
i think you will be happier with s better one. i dont know to much about that one. hut check late model restoration.
Old 05-17-2012, 05:47 AM   #29
93slowstang's Avatar
This one would be a winner, even has a shifter ball. http://www.latemodelrestoration.com/...r-And-Knob-Kit
Old 06-13-2012, 09:57 PM   #30
Installed
Old 06-13-2012, 10:11 PM   #31
Installed
Looks good, how's the shifting now?
Old 06-13-2012, 10:17 PM   #32
Beautiful haha find every excuse I can to just drive
09:47 PM
