EGR valve?? - Mustang Evolution
Old 05-16-2012, 01:41 PM   #1
FLAT BLACK GT's Avatar
EGR valve??
My car is throwing a check engine light once per drive and it goes off.. Its running really rich ive been told that bad maf sensors and egr can throw a light but I wanted anybodys opinion who has been down this road before.. It is also sputtering under throttle at times.. Thanks,
Kc
FLAT BLACK GT is offline   Reply With Quote
Old 05-16-2012, 03:33 PM   #2
Those are good places to start. But I would read the codes and see what they say.
Old 05-16-2012, 05:05 PM   #3
Stang.racr's Avatar
If its got tits or tires it's gonna give you problems my first step would be cleaning the maf and hoping that fixes it
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 05-16-2012, 07:53 PM   #4
SSC182's Avatar
Does the car have problems idling
SSC182 is offline   Reply With Quote
Old 05-17-2012, 06:20 AM   #5
I had oreilys hook it up and it said rich at partial throttle and lean at wot. Not sure what that means. So I guess when I get some cash ill take it to someone professional who can hook it up and pinpoint exactly what's wrong. Ima clean the maf and replace the egr and see what happen..
---------- Post added at 07:20 AM ---------- Previous post was at 07:19 AM ----------
Its been idling a little rough lately
Old 05-17-2012, 10:13 AM   #6
It sounds to me like your stuck in an "open loop" which the ecu will go into default when one of the major sensors that control fuel is faulty. I would still check the basics. All these parts are testable. Get your self a Haynes or Chilton and it should have all the testing procedures.
Old 05-17-2012, 11:31 AM   #7
SSC182's Avatar
If you do take it to a shop tell them to put it on a 5 gas analyzer that will tell you where your problem is. That will tell you why you have a rich condition
Old 05-17-2012, 05:22 PM   #8
Re: EGR valve??
+1
Check your: MAF, O2 sensors, ECT (engine coolant temp) sensor, or AIT (air intake temp) sensor.
02:43 PM
